주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Titan Right Gyroscope Replacement
필요한 것
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 1 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 1 단계, 이미지 2개 중 2개
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    댓글 쓰기
  2. Hover-1 Titan Right Gyroscope Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
    댓글 쓰기
  3. Hover-1 Titan Right Gyroscope Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Titan Right Gyroscope Replacement: 3 단계, 이미지 3개 중 3개
    • Grip the bottom right panel and lift to remove it.
    댓글 쓰기
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 4 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 4 단계, 이미지 2개 중 2개
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
    댓글 쓰기
  5. Hover-1 Titan Right Gyroscope Replacement: 5 단계, 이미지 3개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 5 단계, 이미지 3개 중 2개 Hover-1 Titan Right Gyroscope Replacement: 5 단계, 이미지 3개 중 3개
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
    댓글 쓰기
  6. Hover-1 Titan Right Gyroscope Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 6 단계, 이미지 2개 중 2개
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
    댓글 쓰기
  7. Hover-1 Titan Right Gyroscope Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the white wires by squeezing the connector and pulling away from the board.
    댓글 쓰기
  8. Hover-1 Titan Right Gyroscope Replacement: 8 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 8 단계, 이미지 2개 중 2개
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    댓글 쓰기
  9. Hover-1 Titan Right Gyroscope Replacement: 9 단계, 이미지 2개 중 1개 Hover-1 Titan Right Gyroscope Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    댓글 쓰기
  10. Hover-1 Titan Right Gyroscope Replacement: 10 단계, 이미지 1개 중 1개
    • Cut the cable tie and unplug the remaining wires.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jessica Ouyang
회원 가입일: 10/08/18
634 평판
안내서 4개를 작성함
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 회원
CPSU-WHITE-F18S15G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
Where can I get the circuit boards for the left and right ?
jfsucher - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 1,756
