주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 XLS Battery Replacement
필요한 것
  1. Hover-1 XLS Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Hover-1 XLS Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Hover-1 XLS Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
    댓글 쓰기
  2. Hover-1 XLS Battery Replacement: 2 단계, 이미지 3개 중 1개 Hover-1 XLS Battery Replacement: 2 단계, 이미지 3개 중 2개 Hover-1 XLS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jonathan Hidalgo
회원 가입일: 01/24/19
659 평판
안내서 5개를 작성함
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 회원
CPSU-WHITE-W19S1G2
3 회원들
안내서 13개를 작성함
17가이드 댓글
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - 답글 공유
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - 답글 공유
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - 답글 공유
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - 답글 공유
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 59
지난 30일: 251
전체 시간: 14,342
