주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Reset a Suitcase Lock
    1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: 1 단계, 이미지 2개 중 1개 How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: 1 단계, 이미지 2개 중 2개
      • Set the suitcase down with the combination lock facing up.
      댓글 쓰기
    2. How To Reset a Suitcase Lock: 2 단계, 이미지 1개 중 1개
      • Turn a flashlight towards the lock, so that you can see the small details.
      댓글 쓰기
    3. How To Reset a Suitcase Lock: 3 단계, 이미지 3개 중 1개 How To Reset a Suitcase Lock: 3 단계, 이미지 3개 중 2개 How To Reset a Suitcase Lock: 3 단계, 이미지 3개 중 3개
      • Rotate the three gears together so that the grooved part of each gear faces the outside.
      • Correct: Gear faces the outside.
      • Gear faces the inside.
      댓글 쓰기
    4. How To Reset a Suitcase Lock: 4 단계, 이미지 1개 중 1개
      • Remember the number of the three gears when the groove part is on the outside.
      • As of now the code number of the three gears is 181.
      댓글 쓰기
    5. How To Reset a Suitcase Lock: 5 단계, 이미지 1개 중 1개
      • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
      • Turn the numbers on the lock to 636, and then unlock the lock.
      댓글 쓰기
    6. How To Reset a Suitcase Lock: 6 단계, 이미지 2개 중 1개 How To Reset a Suitcase Lock: 6 단계, 이미지 2개 중 2개
      • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
      • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
      댓글 쓰기
    7. How To Reset a Suitcase Lock: 7 단계, 이미지 2개 중 1개 How To Reset a Suitcase Lock: 7 단계, 이미지 2개 중 2개
      • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
      댓글 쓰기
결론
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lisha Li
회원 가입일: 09/17/21
469 평판
안내서 2개를 작성함
York University, Team E-11, Melo-Thaiss Fall 2021 York University, Team E-11, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG11
1 회원
안내서 7개를 작성함
4가이드 댓글
OMG! A big THANK YOU!!! It worked.
Edward Lee - 답글 공유
Amazing. This worked for me
Leena Daykin - 답글 공유
It worked for me too
georgeteach - 답글 공유
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 156
지난 30일: 708
전체 시간: 58,852
