주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How To Restring a Yo-Yo
필요한 것
  1. How To Restring a Yo-Yo, String: 1 단계, 이미지 1개 중 1개
    • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
    댓글 쓰기
  2. How To Restring a Yo-Yo: 2 단계, 이미지 1개 중 1개
    • Analyze the current state of the string.
    • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
    • If the string is damaged beyond repair, then get your new string ready.
    댓글 쓰기
  3. How To Restring a Yo-Yo: 3 단계, 이미지 1개 중 1개
    • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
    • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
    댓글 쓰기
  4. How To Restring a Yo-Yo: 4 단계, 이미지 1개 중 1개
    • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
    • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
    댓글 쓰기
  5. How To Restring a Yo-Yo: 5 단계, 이미지 1개 중 1개
    • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
    댓글 쓰기
  6. How To Restring a Yo-Yo: 6 단계, 이미지 1개 중 1개
    • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
    • This will ensure that the placement of the string is secure.
    댓글 쓰기
  7. How To Restring a Yo-Yo: 7 단계, 이미지 1개 중 1개
    • Screw the halves back together firmly, making sure that they are aligned correctly.
    • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
    댓글 쓰기
  8. How To Restring a Yo-Yo: 8 단계, 이미지 1개 중 1개
    • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
    댓글 쓰기
결론
After following these steps, you will have successfully restrung your Yo-Yo.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mark Amirthanathan
회원 가입일: 01/19/21
205 평판
안내서 1개를 작성함
1가이드 댓글
nice tutorial
sdsdsds - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 109
전체 시간: 6,142
