주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Change to 12V Power Supply
필요한 것
    • Remove the modem so only the open-storm board remains. This is to prevent accidentally frying the modem.
    댓글 쓰기
    • Remove the JP1 and JP2 jumpers
    댓글 쓰기
    • Plug in the 12V power source
    댓글 쓰기
    • Using a multimeter, touch the ground to any of the ground pinouts on the board and measure the JP1 and JP2 jumpers
    • You should see 12V on the middle and bottom pin of JP1 and 12V on the bottom pin of JP2. The top pin of JP2 should be ~ 3.6V
    댓글 쓰기
    • If ~ 3.6 V measured on top JP2 jumper, then add jumper in new position.
    • JP2 powers the modem so it's very important that it is not supplied the higher voltage, otherwise the modem will fry.
    댓글 쓰기
    • Plug in the 12V power supply again and see if the JP2 jumper measures ~ 3.7V
    댓글 쓰기
    • Unplug the power source and plug in the modem.
    • Be vary careful to not skip a modem pin when plugging in and that it is oriented in the correct direction.
    • Power back on the board and wait to see a green light on the modem (indicating that it is properly powered and trying to connect to the internet).
    댓글 쓰기
결론
To revert back to 3.7V power, flip back the 2 jumpers to how they were at the start of the guide.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Meagan Tobias
회원 가입일: 01/29/19
154 평판
안내서 1개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 277
