주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Clean Corroded Battery Terminals
필요한 것
    1. How to Clean Corroded Battery Terminals, Safety precautions: 1 단계, 이미지 1개 중 1개
      • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
      • If your device still works, power it down completely before starting.
      댓글 쓰기
    2. How to Clean Corroded Battery Terminals, Remove the batteries: 2 단계, 이미지 3개 중 1개 How to Clean Corroded Battery Terminals, Remove the batteries: 2 단계, 이미지 3개 중 2개 How to Clean Corroded Battery Terminals, Remove the batteries: 2 단계, 이미지 3개 중 3개
      • Remove the batteries from your device.
      • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
      • If any batteries are stuck, follow the next step as normal to clean around them.
      댓글 쓰기
    3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 3 단계, 이미지 3개 중 1개 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 3 단계, 이미지 3개 중 2개 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Anti-Static Brush
      $2.99
      • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
      • Use the point of a spudger to pick out any bits that are stuck.
      • Pick around the batteries, and not at the batteries themselves.
      • Flip your device over and gently shake out the loose corrosion and debris.
      • Dispose of the corrosion and debris in the trash.
      댓글 쓰기
    4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: 4 단계, 이미지 2개 중 1개 How to Clean Corroded Battery Terminals, Remove any stuck batteries: 4 단계, 이미지 2개 중 2개
      • You should now be able to remove any batteries that were previously stuck.
      • Clean out the battery recess with a toothbrush.
      댓글 쓰기
    5. How to Clean Corroded Battery Terminals, Clean the terminals: 5 단계, 이미지 3개 중 1개 How to Clean Corroded Battery Terminals, Clean the terminals: 5 단계, 이미지 3개 중 2개 How to Clean Corroded Battery Terminals, Clean the terminals: 5 단계, 이미지 3개 중 3개
      • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
      • Lightly dip a cotton swab in white vinegar or lemon juice.
      • Don't soak the cotton swab. Only use a small amount of liquid at a time.
      • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
      • The corrosion may fizz and bubble. Don't worry, this is normal.
      • Continue this process until there's no corrosion on the terminals.
      댓글 쓰기
    6. How to Clean Corroded Battery Terminals: 6 단계, 이미지 3개 중 1개 How to Clean Corroded Battery Terminals: 6 단계, 이미지 3개 중 2개 How to Clean Corroded Battery Terminals: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Microfiber Cleaning Cloths
      $3.99
      • Isopropyl alcohol will remove any residue left from the previous step.
      • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
      • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
      • Wipe the residue away with a microfiber or lint-free cloth.
      • Repeat this process until the terminals are completely clean.
      • Wait two minutes to allow any residual alcohol to evaporate.
      댓글 쓰기
    7. How to Clean Corroded Battery Terminals, Install new batteries: 7 단계, 이미지 3개 중 1개 How to Clean Corroded Battery Terminals, Install new batteries: 7 단계, 이미지 3개 중 2개 How to Clean Corroded Battery Terminals, Install new batteries: 7 단계, 이미지 3개 중 3개
      댓글 쓰기
결론
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
199,122 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 63,046개를 작성함
2가이드 댓글
Good article, thanks.
MarkDownUnder - 답글 공유
Nice Article . Thanks Bro
TSM Tool - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 46
지난 7일: 521
지난 30일: 2,123
전체 시간: 72,067
