주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Create a Custom Cotton Swab
필요한 것
    1. How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 3개
      • Find a small object with a pointed end, such as:
      • A toothpick
      • A spudger
      • The end of a flossing pick
      • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
      댓글 쓰기
    2. How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 3개
      • Pull off a small part of a cotton ball.
      • You only need a small amount of cotton—enough to create a thin layer around your tool.
      댓글 쓰기
    3. How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 3개
      • Wrap the cotton around the tip of your tool.
      • Roll the cotton between your fingers to compress it into a thin layer.
      댓글 쓰기
    4. How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 3개
      • Test your cotton swab on your device to see if it fits.
      • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
      • If the swab still doesn't fit, you may need to find a different tool altogether.
      • Your custom cotton swab is ready! Return to where you left off in your guide.
      댓글 쓰기
결론
For other general electronics skills guides, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 42명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
246,471 평판
안내서 1,203개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 45,972개를 작성함
4가이드 댓글
My samsung a14 won't charge
Tebogo madibana - 답글 공유
هاتفي لا يشحن بسبب انخفاض درجة حرارته
لست ادري - 답글 공유
My phone shows green light it doesn't seem to charge
Gm Tessema - 답글 공유
Broken screen
Bemnet Yab - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 29
지난 7일: 194
지난 30일: 1,111
전체 시간: 21,788
