주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix Anything
  1. How to Fix Anything, Define the Problem: 1 단계, 이미지 1개 중 1개
    • Try to describe what your device is doing and what instead you expect it to do.
    댓글 쓰기
    • If it is not obvious, check if the behaviour is actually a problem or not.
    • Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
    댓글 쓰기
    • Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
    댓글 쓰기
    • In Europe, everything has two years of warranty by law. Do not give up your rights!
    댓글 쓰기
    • There is a very good chance that you will find something useful with a little search online.
    댓글 쓰기
  2. How to Fix Anything, Talk to your Community: 6 단계, 이미지 1개 중 1개
    • Speak with friends, family or colleagues. Even if they don't know anything, speaking helps a lot the reasoning.
    • Speak to a rubber duck
    댓글 쓰기
  3. How to Fix Anything, Mind the safety.: 7 단계, 이미지 1개 중 1개
    • Take a minute to think if there is anything that could be a safety hazard.
    • Check the user manual and the package, if available, and the device itself for any danger label.
    댓글 쓰기
결론
You are now ready to repair your stuff!
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Davide
회원 가입일: 07/15/16
1,054 평판
안내서 1개를 작성함
6가이드 댓글
How to fix a 1998 fisher seph snow plow
Joseph427!@#$ - 답글 공유
Estaría bien que pusieran un traductor para poder leer los comentarios de la gente
Gracias
Ruiz Marga - 답글 공유
How to fix the spring in a Skoda Enyaq key fob.
Yvonne Pearson - 답글 공유
@yvonnepearson This video shows you how to do it.
VauWeh - 답글 공유
waxa aan ahay
Cabdi Cabdullahi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 65
지난 7일: 284
지난 30일: 982
전체 시간: 12,824
