주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix Broken Powder Make-up
필요한 것
  1. How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: 1 단계, 이미지 3개 중 1개 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: 1 단계, 이미지 3개 중 2개 How to Fix Broken Powder Make-up, How to Fix Broken Powder Make-up: 1 단계, 이미지 3개 중 3개
    • Using the metal butter knife or metal spudger, break up the entire pan of powder into fine pieces.
    댓글 쓰기
  2. How to Fix Broken Powder Make-up: 2 단계, 이미지 3개 중 1개 How to Fix Broken Powder Make-up: 2 단계, 이미지 3개 중 2개 How to Fix Broken Powder Make-up: 2 단계, 이미지 3개 중 3개
    • Pour a small amount of rubbing alcohol into the cap.
    • Slowly add the rubbing alcohol from the cap to the powder and mix it with the knife as you go.
    • Do not use more than two caps worth of rubbing alcohol.
    댓글 쓰기
  3. How to Fix Broken Powder Make-up: 3 단계, 이미지 2개 중 1개 How to Fix Broken Powder Make-up: 3 단계, 이미지 2개 중 2개
    • The powder will become creamy with no chunks or bumps. Use the side of the knife to smooth over the top surface.
    댓글 쓰기
  4. How to Fix Broken Powder Make-up: 4 단계, 이미지 1개 중 1개
    • To completely smooth over the top surface, use a clean finger to push out the edges and even out the surface.
    댓글 쓰기
  5. How to Fix Broken Powder Make-up: 5 단계, 이미지 1개 중 1개
    • Wait a few hours to let dry before closing the lid. The rubbing alcohol will evaporate, leaving you with a pressed solid ready for re-use.
    • If the powder is not fully dry, let it sit for another hour and continue to check back.
    댓글 쓰기
결론
These steps can be used to fix any type of powder makeup (ie. eyeshadows, blush, etc.)
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Meghan Smith
회원 가입일: 04/09/15
224 평판
안내서 1개를 작성함
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 회원
CPSU-GREEN-S15S30G3
4 회원들
안내서 10개를 작성함
1가이드 댓글
It's also good to mash the surface down with something flat like a coin on top of a paper towel, while it's still a little malleable. This way, you get an even, similar texture as when it was new.
Great guide!
Kim Arre - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 61
전체 시간: 2,413
