주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix a not working metering mode
필요한 것
    • Remove the Memory Card(s) from the camera
    • Remove the Battery from the Camera, and close the battery compartment cover
    댓글 쓰기
  1. How to Fix a not working metering mode, Remove 2 exposed screws: 2 단계, 이미지 1개 중 1개
    • Remove the 2 screws beside the memory slots, then close the cover.
    • Note: make sure to remove the memory cards first!
    댓글 쓰기
  2. How to Fix a not working metering mode, Remove 2 screws under grip: 3 단계, 이미지 1개 중 1개
    • Remove the 2 screws under the rubber grip part by peeling back the rubber grip
    • Try not to damage the double sided adhesive under the rubber.
    댓글 쓰기
  3. How to Fix a not working metering mode, Remove 2 screws under rear grip: 4 단계, 이미지 1개 중 1개
    • Remove the 2 screws under the rubber pad marked in red.
    • Try not to damage the double-sided adhesive under the rubber.
    • Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
    댓글 쓰기
    • Lift out the assembly panel, it should come free without much force.
    • May open the panel to release it.
    댓글 쓰기
  4. How to Fix a not working metering mode, Remove top screw: 6 단계, 이미지 1개 중 1개
    • Remove the screw above the viewfinder
    댓글 쓰기
  5. How to Fix a not working metering mode, Remove the bottom panel plate: 7 단계, 이미지 1개 중 1개
    • Remove the 4 screws holding the plate to the bottom.
    • Remove the bottom plate
    댓글 쓰기
  6. How to Fix a not working metering mode, Remove screws from the bottom: 8 단계, 이미지 1개 중 1개
    • Remove the 4 screws (1 was under the plate removed under the last step)
    댓글 쓰기
  7. How to Fix a not working metering mode, Remove Screw under grip: 9 단계, 이미지 1개 중 1개
    • Remove the screw under the grip, if it has not been removed doing a previous step
    댓글 쓰기
  8. How to Fix a not working metering mode, Remove Screw on Left: 10 단계, 이미지 1개 중 1개
    • Remove the exposed screw on the Left side
    댓글 쓰기
  9. How to Fix a not working metering mode, Carefully remove the back assembly: 11 단계, 이미지 1개 중 1개
    • Carefully pull the back plate off the camera
    • There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
    • To release the cables by flipping up the tap on the side away from the cable
    • When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
    • The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
    • The black LCD cable does have less slack, so is easier to release first, and reconnect last.
    댓글 쓰기
  10. How to Fix a not working metering mode, Remove Grip: 12 단계, 이미지 1개 중 1개
    • Carefully remove the Rubber grip from the camera
    • Careful to not damage the double-sided adhesive
    댓글 쓰기
  11. How to Fix a not working metering mode, Remove the Left Rubber: 13 단계, 이미지 1개 중 1개
    댓글 쓰기
  12. How to Fix a not working metering mode, Disconnect the diopter: 14 단계, 이미지 1개 중 1개
    • Remove the diopter cap from the end of the diopter (use a flat head or pry tool)
    • Un-screw the phillips screw from the diopter
    • When reconnecting, make sure the cap is seated in correctly and the double sided tape is not damaged (or replace)
    • There is a notch which the indicator has to seat into, or it will not sit down correctly when it is reinstalled.
    댓글 쓰기
  13. How to Fix a not working metering mode, Remove Screw on Right: 15 단계, 이미지 1개 중 1개
    • Remove the screw that had been hidden under the memory slot cover.
    댓글 쓰기
  14. How to Fix a not working metering mode, Remove Front Screws: 16 단계, 이미지 1개 중 1개
    • Remove the screw under the top assembly, had been hidden by the grip.
    • Remove the 2 screws from the bottom of the mirror box
    • Remove the lens or lenscap prior to doing this step to gain access, then reattach.
    • Remove the screw from beside the accessory socket
    댓글 쓰기
  15. How to Fix a not working metering mode, Remove Screw on Left: 17 단계, 이미지 1개 중 1개
    • Remove the screw from the left side, had been hidden under the rubber
    댓글 쓰기
  16. How to Fix a not working metering mode, Disconnect from main board: 18 단계, 이미지 1개 중 1개
    • Disconnect the 2 ribbon cables from the main board (Red boxes)
    • Lift the black tabs above the cables to release the cables
    • When reseating the cables, make sure they are fully seated before closing the locking tab
    • Note: there is another ribbon cable under the left one which goes to the 10-pin accessory port, make sure it's seated correctly when reassembling.
    • Disconnect the wifi sub-board with the wifi cable from the main board (Blue Box) or gently disconnect the wifi antenna (Blue circle)
    • The antenna connector is very delicate, and isn't designed for many cycles, which is why the board is recommended (it has a socket it fits into.
    댓글 쓰기
  17. How to Fix a not working metering mode, Lift Top assembly free: 19 단계, 이미지 3개 중 1개 How to Fix a not working metering mode, Lift Top assembly free: 19 단계, 이미지 3개 중 2개 How to Fix a not working metering mode, Lift Top assembly free: 19 단계, 이미지 3개 중 3개
    • Carefully lift the top assembly free.
    • Note, there is a thermal pad on the left hand side, almost right under where the strap lug is. Red Box. Careful to not damage it.
    댓글 쓰기
  18. How to Fix a not working metering mode, Identify area: 20 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Once the top assembly is disconnected from the rest of the camera, the area for the service is highlighted in the green.
    • Connect an anti-static strap to the magnesium shell, making sure it touches some unpainted part, to make sure you don't damage any components.
    • (This picture came from an ebay part listing)
    댓글 쓰기
  19. How to Fix a not working metering mode, Remove screw: 21 단계, 이미지 1개 중 1개
    • Carefully remove the retaining screw that secures the soft ribbon cable that has components on it.
    • Careful to not damage the part in any way, as may break traces.
    댓글 쓰기
  20. How to Fix a not working metering mode, Locate Mode Dial wiring harness: 22 단계, 이미지 1개 중 1개
    • Once unfolded, Locate the white socket with the tiny ribbon cable (it's about about 4 mm wide), cable highlighted with blue
    댓글 쓰기
  21. How to Fix a not working metering mode, Disconnect wiring harness for Mode Dial: 23 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, gently release the latch part of the socket. The latch is on the side away from the socket
    • Release the wiring harness from the socket, careful to not damage it.
    댓글 쓰기
  22. How to Fix a not working metering mode, Inspect and reseat harness: 24 단계, 이미지 1개 중 1개
    • Inspect the end of the connector for any corrosion, remediating if any is found.
    • Reseat harness in the connector gently, using tweezers. Make sure the cable is correctly seated and seated correctly.
    • Engage the latch holding the harness into place.
    댓글 쓰기
    • I use a tiny bit of tape to help keep the harness from moving at all. This would be optional, as if it's still under warranty, would make it obvious someone had opened the camera up.
    댓글 쓰기
    • (Sorry, do not have an image for this step)
    • Fold the flex cable back up, and secure with the screw, careful to not over tighten.
    댓글 쓰기
결론
To reassemble the camera, follow the Prerequisite guides in reverse order.
  • Make sure all ribbon cables are fully seated before closing the latch, or the camera may not work correctly
  • Make sure the camera is fully functional, to confirm all the parts were connected correctly.
  • Many screws are into plastic, make sure to not over-tighten them
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Wolphin
회원 가입일: 11/11/19
1,795 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 40
전체 시간: 1,861
