주요 콘텐츠로 건너뛰기
How to Force Restart iPhone X
  1. How to Force Restart iPhone X, How to Force Restart iPhone X: 1 단계, 이미지 1개 중 1개
    • Quickly press and release the volume-up button (1).
    • Quickly press and release the volume-down button (2).
  2. How to Force Restart iPhone X: 2 단계, 이미지 1개 중 1개
    • Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    • The screen will temporarily go dark as the iPhone shuts down and reboots. Keep holding the button until you see the  logo.
결론
You're done!
다른 137명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
[deleted]
8,492 평판
안내서 12개를 작성함
14가이드 댓글
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - 답글
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - 답글
good share. thanks.
MelissaR - 답글
What is the other way?
sa sas - 답글
will it delete all data from my iPhone?
_TR0xuu_ - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 128
지난 30일: 546
전체 시간: 370,897
