주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Install Ubuntu Linux
필요한 것
    1. How to Install Ubuntu Linux, Download Ubuntu: 1 단계, 이미지 1개 중 1개
      댓글 쓰기
    2. How to Install Ubuntu Linux, Burn to Disk: 2 단계, 이미지 2개 중 1개 How to Install Ubuntu Linux, Burn to Disk: 2 단계, 이미지 2개 중 2개
      • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
      • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
      댓글 쓰기
    3. How to Install Ubuntu Linux, Boot to installation media: 3 단계, 이미지 1개 중 1개
      • I recommend trying Ubuntu in a virtual machine, which is what I did.
      • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
      • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
      • If you have successfully booted into the installation media, you will see this picture.
      • Click on the big "Install Ubuntu" button.
      댓글 쓰기
    4. How to Install Ubuntu Linux, Install Ubuntu: 4 단계, 이미지 1개 중 1개
      • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
      • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
      • If you are experienced with partitions, you may use this partition editor.
      • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
      댓글 쓰기
결론
That's it! Now you can try Ubuntu all you want.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Thomas Sirack
회원 가입일: 07/25/15
561 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,568
