주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Install and Remove Tiles
필요한 것
    1. How to Install and Remove Tiles, Remove the Front Panel: 1 단계, 이미지 3개 중 1개 How to Install and Remove Tiles, Remove the Front Panel: 1 단계, 이미지 3개 중 2개 How to Install and Remove Tiles, Remove the Front Panel: 1 단계, 이미지 3개 중 3개
      • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
      댓글 쓰기
    1. How to Install and Remove Tiles, Remove the Tiles: 2 단계, 이미지 3개 중 1개 How to Install and Remove Tiles, Remove the Tiles: 2 단계, 이미지 3개 중 2개 How to Install and Remove Tiles, Remove the Tiles: 2 단계, 이미지 3개 중 3개
      • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
      • Remove the Tile.
      댓글 쓰기
    2. How to Install and Remove Tiles: 3 단계, 이미지 3개 중 1개 How to Install and Remove Tiles: 3 단계, 이미지 3개 중 2개 How to Install and Remove Tiles: 3 단계, 이미지 3개 중 3개
      • Repeat this procedure for the remaining tiles.
      댓글 쓰기
    1. How to Install and Remove Tiles, Install the Tiles: 4 단계, 이미지 3개 중 1개 How to Install and Remove Tiles, Install the Tiles: 4 단계, 이미지 3개 중 2개 How to Install and Remove Tiles, Install the Tiles: 4 단계, 이미지 3개 중 3개
      • Tiles can be installed in any orientation, even the ones with graphics.
      • Lay a Tile over an open slot on your Front Panel.
      • Use your fingers to press the tile into the slot and engage the clips.
      • You'll hear and feel an audible "click" when the clips engage.
      댓글 쓰기
    2. How to Install and Remove Tiles: 5 단계, 이미지 3개 중 1개 How to Install and Remove Tiles: 5 단계, 이미지 3개 중 2개 How to Install and Remove Tiles: 5 단계, 이미지 3개 중 3개
      • Install the remaining Tiles.
      댓글 쓰기
    3. How to Install and Remove Tiles: 6 단계, 이미지 3개 중 1개 How to Install and Remove Tiles: 6 단계, 이미지 3개 중 2개 How to Install and Remove Tiles: 6 단계, 이미지 3개 중 3개
      • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
      • Press the Front Panel flat to the chassis and let it align to the magnets.
      댓글 쓰기
결론
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
246,003 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 40
전체 시간: 391
