주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to JBL L40
필요한 것
    1. How to JBL L40, How to JBL L40: 1 단계, 이미지 1개 중 1개
      • To remove the speaker from the cabinet, unscrew the 4 screws being careful not to slip and pierce the paper cone.
      • Once the screws are removed gently pull the speaker out of the cabinet.
      • There will be 2 wires attached to the speaker, remove them making sure to mark the polarity of them if they are not marked already.
      댓글 쓰기
    2. How to JBL L40: 2 단계, 이미지 1개 중 1개
      • Here is the speaker removed from the cabinet, you can clearly see the degraded state of the foam surround. Luckily this makes it very easy to remove it.
      • These next steps require careful attention to detail. Work slowly and carefully. You do not want to puncture/tear/rip the paper cone or any other components.
      댓글 쓰기
      • Remove the black foam ring.
      • Try to do as much of this by hand as you can. You do not want to damage the ring as you will need it for re assembly.
      • Carefully run your knife between the ring and the outer metal edge.
      • Now using your hands and knife when needed remove the black ring from the speaker frame. Prying slowly. Take care not to tear it.
      • Once the ring is removed rub all of the old foam surround off and set aside for reassembly
      댓글 쓰기
      • Remove all of the old foam surround from the cone and speaker frame. It was so crumbly on mine that all it took was a bunch of rubbing with my fingers. If you are having trouble use your knife, but again be careful.
      댓글 쓰기
    3. How to JBL L40: 5 단계, 이미지 1개 중 1개
      • You can see some of the glue seeped out, it will dry clear so don't worry.
      댓글 쓰기
    4. How to JBL L40: 6 단계, 이미지 1개 중 1개
      • Spread glue on the ring you removed earlier
      • place over the foam ring and press on securly
      • allow everything over night to dry completely.
      댓글 쓰기
    5. How to JBL L40: 7 단계, 이미지 1개 중 1개
      • Connect the wires to the speaker being mindfull of the polarity.
      • Gently fit the speaker into the housing
      • Line up the screws and progressively tighten them until the speaker is secured
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
David Salerno
회원 가입일: 09/14/11
823 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 51
전체 시간: 7,855
