주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Machine Wash a Wader
필요한 것
    1. How to Machine Wash a Wader, Prepare the wader: 1 단계, 이미지 2개 중 1개 How to Machine Wash a Wader, Prepare the wader: 1 단계, 이미지 2개 중 2개
      • Shake off any excess dirt, zip all zippers, and remove any detachable parts like waistbands or belts.
      댓글 쓰기
    2. How to Machine Wash a Wader, Secure the straps and fasteners: 2 단계, 이미지 3개 중 1개 How to Machine Wash a Wader, Secure the straps and fasteners: 2 단계, 이미지 3개 중 2개 How to Machine Wash a Wader, Secure the straps and fasteners: 2 단계, 이미지 3개 중 3개
      • Untangle any straps.
      • Close or clip any fasteners or buckles.
      댓글 쓰기
    3. How to Machine Wash a Wader, Load the washing machine: 3 단계, 이미지 2개 중 1개 How to Machine Wash a Wader, Load the washing machine: 3 단계, 이미지 2개 중 2개
      • Put your waders in the washing machine.
      • Add detergent to the washing machine. You can use special technical gear soap or gentle laundry detergent.
      • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
      댓글 쓰기
    4. How to Machine Wash a Wader, Set the washing machine: 4 단계, 이미지 2개 중 1개 How to Machine Wash a Wader, Set the washing machine: 4 단계, 이미지 2개 중 2개
      • Set the load size to small.
      • Set the water temperature to cold.
      • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
      • Set the spin cycle to low.
      • Start the washing machine.
      댓글 쓰기
    5. How to Machine Wash a Wader, Dry the waders: 5 단계, 이미지 3개 중 1개 How to Machine Wash a Wader, Dry the waders: 5 단계, 이미지 3개 중 2개 How to Machine Wash a Wader, Dry the waders: 5 단계, 이미지 3개 중 3개
      • Let your waders drip dry as soon as possible by hanging them somewhere and letting excess water drip off.
      • Air dry the inside of your waders by turning them inside-out and hanging them in a shaded, well-ventilated area until the inside is completely dry.
      • You can do this outdoors or in the area where you plan to store them. Laundry lines, ladders, and trees are all great options for air drying. This may take up to 24 hours.
      • Air dry the outside of your waders by turning them right-side-out and hanging them in a shaded, well-ventilated area until the outside is completely dry.
      • Store your waders properly by hanging them by the shoulder straps or on a specialty wader hanger in a well-ventilated storage space.
      • Avoid using a dryer unless the waders have been deeply cleaned with soap first.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
246,887 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 33
전체 시간: 635
