주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Open and Clean a PlayStation 4
필요한 것
  1. How to Open and Clean a PlayStation 4, Flip over the PS4: 1 단계, 이미지 1개 중 1개
    • Flip your PS4 upside-down with the back side facing towards you.
  2. How to Open and Clean a PlayStation 4, Remove the rear stickers: 2 단계, 이미지 3개 중 1개 How to Open and Clean a PlayStation 4, Remove the rear stickers: 2 단계, 이미지 3개 중 2개 How to Open and Clean a PlayStation 4, Remove the rear stickers: 2 단계, 이미지 3개 중 3개
    • Stickers cover the screws securing the PS4's outer case.
    • Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
    • Remove the two stickers at the outer edges, exposing two more screws.
  3. How to Open and Clean a PlayStation 4, Remove the rear case screws: 3 단계, 이미지 1개 중 1개
    • Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
  4. How to Open and Clean a PlayStation 4, Remove the lower case: 4 단계, 이미지 2개 중 1개 How to Open and Clean a PlayStation 4, Remove the lower case: 4 단계, 이미지 2개 중 2개
    • Use your thumbs to lift the lower case up and off the PS4.
    • In addition to the three rear screws, the lower case is held in place by plastic clips. You may need to use significant force to release the lower case.
  5. How to Open and Clean a PlayStation 4, Disconnect the power supply: 5 단계, 이미지 2개 중 1개 How to Open and Clean a PlayStation 4, Disconnect the power supply: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Small Needle Nose Pliers
    $6.99
    • Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
    • Depending on the age of your console, this cable might be very firmly connected. If it feels stuck, don't pull on the cables themselves with much force.
    • Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
    • In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
    • Go slow: pulling on the cables themselves might rip them out of the connector.
  6. How to Open and Clean a PlayStation 4, Remove the power supply unit: 6 단계, 이미지 2개 중 1개 How to Open and Clean a PlayStation 4, Remove the power supply unit: 6 단계, 이미지 2개 중 2개
    • Remove three 9.7 mm-long TR8 Torx security screws.
    • Remove two 41 mm-long Phillips screws and brackets.
  7. How to Open and Clean a PlayStation 4: 7 단계, 이미지 3개 중 1개 How to Open and Clean a PlayStation 4: 7 단계, 이미지 3개 중 2개 How to Open and Clean a PlayStation 4: 7 단계, 이미지 3개 중 3개
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  8. How to Open and Clean a PlayStation 4, Clean the fan: 8 단계, 이미지 2개 중 1개 How to Open and Clean a PlayStation 4, Clean the fan: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Dust Blower
    $19.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
  9. How to Open and Clean a PlayStation 4, Clean the case: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
  10. How to Open and Clean a PlayStation 4, Clean vents and hard-to-reach areas: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Brush
    $2.99
    • Depending on how dirty your console is, you might need to use a soft-bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard-to-reach areas and off the rear vents.
    • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
  11. How to Open and Clean a PlayStation 4, Clean the heatsink: 11 단계, 이미지 2개 중 1개 How to Open and Clean a PlayStation 4, Clean the heatsink: 11 단계, 이미지 2개 중 2개
    • The PS4 draws air through the heatsink fins, and they may clog with dust and debris over time.
    • If you can see dust buildup in the heatsink, dislodge debris with a brush and use a dust blower to blow it clean.
    • Remember: use this time to clean any other dirty internal surfaces before you reseal your console. Happy gaming!
결론
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 4 Answers community for help.
다른 48명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
163,815 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,572개를 작성함
3가이드 댓글
Thanks for the help now my ps4 runs quetly you Are a plessing.🙂
Martin1234 - 답글 공유
eu limpei a minha e nao voltou a ligar, o que que eu faço
David Almeida - 답글 공유
quem souber de algo ajude pfvr
David Almeida - 공유
댓글 쓰기
조회 통계:
지난 24시간: 104
지난 7일: 772
지난 30일: 3,739
전체 시간: 85,355
