주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 안내서에는 최근 변경 사항이 있습니다. 최신 확인되지 않은 버전 으로 전환하세요.
How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: 1 단계, 이미지 3개 중 1개 How to Perform a Battery Cycle Reset, Download the app: 1 단계, 이미지 3개 중 2개 How to Perform a Battery Cycle Reset, Download the app: 1 단계, 이미지 3개 중 3개
    • Download the Self Repair Assistant app from ApkMirror (2.0.44)
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
    댓글 쓰기
  2. How to Perform a Battery Cycle Reset, Install the app: 2 단계, 이미지 2개 중 1개 How to Perform a Battery Cycle Reset, Install the app: 2 단계, 이미지 2개 중 2개
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
    댓글 쓰기
  3. How to Perform a Battery Cycle Reset, Rename the app: 3 단계, 이미지 3개 중 1개 How to Perform a Battery Cycle Reset, Rename the app: 3 단계, 이미지 3개 중 2개 How to Perform a Battery Cycle Reset, Rename the app: 3 단계, 이미지 3개 중 3개
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
    댓글 쓰기
  4. How to Perform a Battery Cycle Reset: 4 단계, 이미지 3개 중 1개 How to Perform a Battery Cycle Reset: 4 단계, 이미지 3개 중 2개 How to Perform a Battery Cycle Reset: 4 단계, 이미지 3개 중 3개
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
    댓글 쓰기
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: 5 단계, 이미지 2개 중 1개 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: 5 단계, 이미지 2개 중 2개
    • Select the Galaxy Cal app.
    댓글 쓰기
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: 6 단계, 이미지 1개 중 1개
    • Select "Agree" to accept the Terms and Conditions.
    댓글 쓰기
  7. How to Perform a Battery Cycle Reset, Select the procedure: 7 단계, 이미지 2개 중 1개 How to Perform a Battery Cycle Reset, Select the procedure: 7 단계, 이미지 2개 중 2개
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
    댓글 쓰기
  8. How to Perform a Battery Cycle Reset: 8 단계, 이미지 3개 중 1개 How to Perform a Battery Cycle Reset: 8 단계, 이미지 3개 중 2개 How to Perform a Battery Cycle Reset: 8 단계, 이미지 3개 중 3개
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
244,748 평판
안내서 1,203개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,226개를 작성함
50가이드 댓글
Rabe - 답글 공유
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi - 답글 공유
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - 답글 공유
I have the same. Do you know how to fix this now?
Melanie Herget - 답글 공유
simply change your phone date between 2021 and 2022.
mightnire - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 109
지난 7일: 919
지난 30일: 4,380
전체 시간: 135,234
