주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reattach a Backpack Grab Handle
필요한 것
    1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 1 단계, 이미지 3개 중 1개 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 1 단계, 이미지 3개 중 2개 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 1 단계, 이미지 3개 중 3개
      • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
      • Caution: Be careful when using scissors this way.
      댓글 쓰기
    2. How to Reattach a Backpack Grab Handle: 2 단계, 이미지 2개 중 1개 How to Reattach a Backpack Grab Handle: 2 단계, 이미지 2개 중 2개
      • Open up the inner seam at the same spot using a pair of scissors.
      댓글 쓰기
    3. How to Reattach a Backpack Grab Handle: 3 단계, 이미지 2개 중 1개 How to Reattach a Backpack Grab Handle: 3 단계, 이미지 2개 중 2개
      • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
      댓글 쓰기
    4. How to Reattach a Backpack Grab Handle: 4 단계, 이미지 3개 중 1개 How to Reattach a Backpack Grab Handle: 4 단계, 이미지 3개 중 2개 How to Reattach a Backpack Grab Handle: 4 단계, 이미지 3개 중 3개
      • Thread your sewing needle.
      • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
      댓글 쓰기
    5. How to Reattach a Backpack Grab Handle: 5 단계, 이미지 3개 중 1개 How to Reattach a Backpack Grab Handle: 5 단계, 이미지 3개 중 2개 How to Reattach a Backpack Grab Handle: 5 단계, 이미지 3개 중 3개
      • Hold the edge of your grab handle down at the the first seam you opened.
      • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
      • Caution: Sewing needles are sharp; be careful not to poke yourself.
      • This repair only requires one of these two basic stitching methods.
      댓글 쓰기
    6. How to Reattach a Backpack Grab Handle: 6 단계, 이미지 2개 중 1개 How to Reattach a Backpack Grab Handle: 6 단계, 이미지 2개 중 2개
      • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
      • Use one of these basic stitching methods.
      댓글 쓰기
    7. How to Reattach a Backpack Grab Handle: 7 단계, 이미지 3개 중 1개 How to Reattach a Backpack Grab Handle: 7 단계, 이미지 3개 중 2개 How to Reattach a Backpack Grab Handle: 7 단계, 이미지 3개 중 3개
      • Cut off the remaining thread and tie it into a knot.
      댓글 쓰기
결론
Once you have completed this guide, you will be able to make use of your grab handle once again.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Onyinyechi Onyeagucha
회원 가입일: 01/19/21
342 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 40
지난 30일: 190
전체 시간: 11,660
