주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reduce MacBook Pro Core Temperature
필요한 것
    1. How to Reduce MacBook Pro Core Temperature, Dissassembly: 1 단계, 이미지 1개 중 1개
      • First off you'll need to locate a disassembly guide for your machine and follow it carefully to remove the logic board.
      • If you haven't already, this would be a good opportunity to follow a guide for replacing the thermal paste.
      댓글 쓰기
    2. How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: 2 단계, 이미지 3개 중 1개 How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: 2 단계, 이미지 3개 중 2개 How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: 2 단계, 이미지 3개 중 3개
      • The aim here is to sandwich thick thermal pads under you MacBook's heatsinks to contact the upper case, and atop them to contact the bottom cover. This will help conduct heat away from the machine by effectively making the entire unibody one big heatsink.
      • On my machine, a mid-2010 15 inch MBP, I needed to use three strips of a 2mm thick thermal pad under the centre heatsink, two strips under the side one and one strip atop each to make contact with the bottom cover.
      • Try to use enough layers that the heatsinks are in good contact, but not so many that anything needs to bend to fit back.
      댓글 쓰기
결론
Now reassemble your MacBook by following the disassembly guide in reverse-order. Always monitor your system's temperatures before running any heavy applications just in case something went wrong.
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dan
회원 가입일: 10/22/14
2,463 평판
안내서 3개를 작성함
1가이드 댓글
This ist crazy.
Went from 55 idle to 30 idle and a top end of 83°c instead of throttling.
(13” retina macbook pro)
Peter Nemeth - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 106
전체 시간: 18,052
