주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Remove Rust from a Screwdriver
필요한 것
  1. How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: 1 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: 1 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: 1 단계, 이미지 3개 중 3개
    • Use a clean rag to wipe the screwdriver to remove any dirt, grease, or debris.
    댓글 쓰기
  2. How to Remove Rust from a Screwdriver: 2 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver: 2 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver: 2 단계, 이미지 3개 중 3개
    • In a bowl, stir half a tablespoon of baking soda with 4 to 5 drops of water.
    • Add one eighth teaspoon of baking soda if the mixture is too runny, or 4 to 5 drops of water if the paste is too thick.
    • Adjust the amount of baking soda and water based on the size of the screwdriver.
    댓글 쓰기
  3. How to Remove Rust from a Screwdriver: 3 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver: 3 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver: 3 단계, 이미지 3개 중 3개
    • Apply the paste with moderate pressure, while making sure to fully cover all the rusted areas on the screwdriver.
    • If too much pressure is applied, the paste will fall off. If too little pressure is applied, the paste won't stick.
    댓글 쓰기
  4. How to Remove Rust from a Screwdriver: 4 단계, 이미지 1개 중 1개
    • Allow the paste to sit on the rusted areas for 2 to 6 hours.
    • For heavily rusted screwdrivers, let the paste sit overnight.
    댓글 쓰기
  5. How to Remove Rust from a Screwdriver: 5 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver: 5 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver: 5 단계, 이미지 3개 중 3개
    • After 2 to 6 hours, use a toothbrush or some sort of brush to scrub the paste off the screwdriver.
    • Apply moderate pressure in back and forth and circle motions to effectively remove the rust.
    댓글 쓰기
  6. How to Remove Rust from a Screwdriver: 6 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver: 6 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver: 6 단계, 이미지 3개 중 3개
    • Rinse the screwdriver with clean water to remove any remaining paste.
    • Hot water that can be comfortably handled will remove the paste better.
    • Do not use boiling water, otherwise you can injure yourself. Make sure to use hot tap water.
    댓글 쓰기
  7. How to Remove Rust from a Screwdriver: 7 단계, 이미지 3개 중 1개 How to Remove Rust from a Screwdriver: 7 단계, 이미지 3개 중 2개 How to Remove Rust from a Screwdriver: 7 단계, 이미지 3개 중 3개
    • Using a clean rag, dry the screwdriver by wiping it in a back and forth motion.
    • Make sure the screwdriver is fully dry, otherwise the rust can return.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Varun Sharma
회원 가입일: 07/03/24
253 평판
안내서 1개를 작성함
York University, Team 1-25, O'Regan Summer 2024 York University, Team 1-25, O'Regan Summer 2024 회원
YORK-O'REGAN-SU24S1G25
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 68
전체 시간: 1,329
