주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Replace Keys on a Keyboard
필요한 것
    1. How to Replace Keys on a Keyboard, Individual Keys: 1 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard, Individual Keys: 1 단계, 이미지 2개 중 2개
      • Loosen the key by prying all four corners gently with your spudger.
      • Make sure your keyboard is unplugged before performing any of these steps.
      댓글 쓰기
    2. How to Replace Keys on a Keyboard: 2 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard: 2 단계, 이미지 2개 중 2개
      • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
      • If the key will not come out, or seems like too much force is needed, try step one again.
      댓글 쓰기
    3. How to Replace Keys on a Keyboard: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
      • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
      댓글 쓰기
    4. How to Replace Keys on a Keyboard: 4 단계, 이미지 1개 중 1개
      • Clean your keys with compressed air by blowing around the removed key.
      댓글 쓰기
    5. How to Replace Keys on a Keyboard: 5 단계, 이미지 2개 중 1개 How to Replace Keys on a Keyboard: 5 단계, 이미지 2개 중 2개
      • Push in the clean keys until you hear a popping sound.
      • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
      • If you removed multiple keys, make sure they are in their proper spot and orientation.
      댓글 쓰기
결론
Congratulations! You now have a keyboard with fully functional keys!
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cooper
회원 가입일: 02/24/15
502 평판
안내서 2개를 작성함
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 회원
CPSU-GREEN-W15S24G6
4 회원들
안내서 28개를 작성함
2가이드 댓글
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - 답글 공유
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 42
지난 30일: 191
전체 시간: 21,662
