주요 콘텐츠로 건너뛰기
How to Replace a Rear Brake Cable
필요한 것
  1. How to Replace a Rear Brake Cable, Rear Brake Cable: 1 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable, Rear Brake Cable: 1 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable, Rear Brake Cable: 1 단계, 이미지 3개 중 3개
    • Using the smart wrench and socket wrench, remove the nuts that are holding the connector to the old brake line.
    • After taking apart the connector, slide the screw off the brake line.
    • The nut may be difficult to remove if it has not been removed for a while.
    • Keep in mind the order the parts came off the connector. This will make reassembly easier.
  2. How to Replace a Rear Brake Cable: 2 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 2 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 2 단계, 이미지 3개 중 3개
    • Remove the cable housing from its holders.
    • Slide the housing off the brake cable.
  3. How to Replace a Rear Brake Cable: 3 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 3 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 3 단계, 이미지 3개 중 3개
    • Remove the second cable housing from its holder.
    • Unscrew the other end of the housing from the brake.
    • Remove the housing from the cable.
  4. How to Replace a Rear Brake Cable: 4 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 4 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 4 단계, 이미지 3개 중 3개
    • Apply pressure to the brake to reveal the end of the brake cable.
    • Remove the cable from its holder within the brake.
    • Pull the remaining cable through the brake.
  5. How to Replace a Rear Brake Cable: 5 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 5 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 5 단계, 이미지 3개 중 3개
    • Flip your bike to make the brake housing more visible.
    • Insert the new brake cable into the brake housing.
  6. How to Replace a Rear Brake Cable: 6 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 6 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 6 단계, 이미지 3개 중 3개
    • Slide the cable housing onto the new cable.
    • Re-insert the housing back into its holders.
  7. How to Replace a Rear Brake Cable: 7 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 7 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 7 단계, 이미지 3개 중 3개
    • Slide the rear cable housing onto the new brake cable.
    • Re-insert the housing into its holders.
  8. How to Replace a Rear Brake Cable: 8 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 8 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 8 단계, 이미지 3개 중 3개
    • Slide the screw and washer onto the end of the brake cable.
    • Slide the connector of over the screw and tighten the nut and washer on the other end by hand, so it can slide along the brake cable.
  9. How to Replace a Rear Brake Cable: 9 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 9 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 9 단계, 이미지 3개 중 3개
    • Flip bike back right-side-up.
    • Slide the connector up near the housing holder. About an inch between the connector and holder should be fine.
    • Using the smart wrench and 10mm socket wrench, tighten the nut so it grips the brake line firmly.
    • Using wire-cutters, cut the extra cable so only about an inch remains.
  10. How to Replace a Rear Brake Cable: 10 단계, 이미지 3개 중 1개 How to Replace a Rear Brake Cable: 10 단계, 이미지 3개 중 2개 How to Replace a Rear Brake Cable: 10 단계, 이미지 3개 중 3개
    • You can recycle the old brake cable for this.
    • Insert the end of the brake cable with a "nub" into the slot on the rear left brake.
    • Slide the cable onto the slot on the connector.
    • Slide the other end of the cable into the holder on the right rear brake.
    • Pull the cable to clamp down the brakes so they almost touch the rim of the wheel.
    • Tighten the screw so the cable does not come loose.
결론
You now should have a fully function rear brake on your bike.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Valdez
회원 가입일: 02/24/15
276 평판
안내서 1개를 작성함
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 회원
CPSU-GREEN-W15S23G4
7 회원들
안내서 15개를 작성함
댓글 한 개
Добар текст са доста слика ево и текст са истом тему https://www.diyany.net/bicycle-cable-rep...
DiY AnY - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 55
전체 시간: 14,375
