주요 콘텐츠로 건너뛰기
How to Replace the Screen Adhesive for Your Google Pixel 7 Pro
필요한 것
  1. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 1 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 1 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Any residual adhesive or debris will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive as you can.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Take care not to puncture the battery with your tweezers—a punctured battery may leak dangerous chemicals or cause a fire.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 2 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 2 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: 2 단계, 이미지 3/3
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: 3 단계, 이미지 1/2 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: 3 단계, 이미지 2/2
    • Before applying the new adhesive, lay it over the frame to find its proper orientation.
    • Use features such as the front-facing camera, upper loudspeaker, and corner notches to orient the adhesive.
  4. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the adhesive backing: 4 단계, 이미지 1/1
    • Use the pull tab on the top of the adhesive to remove the clear protective backing.
  5. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 5 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 5 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: 5 단계, 이미지 3/3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom edge. Make small corrections as you go.
    • Use the bottom left notch, top right notch, and upper loudspeaker cutout to help align the adhesive.
  6. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 6 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 6 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 6 단계, 이미지 3/3
    • Use a spudger or your fingers to firmly press along the perimeter of the adhesive and adhere it to the frame.
  7. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 7 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 7 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: 7 단계, 이미지 3/3
    • Grab the pull tab on the lower right of the frame and peel off the main liner.
    • There's a smaller liner under this one. Don't remove it yet.
  8. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Check for liners: 8 단계, 이미지 1/1
    • Check the front-facing camera hole and sensor cutout on the replacement screen and remove any remaining protective liners in it.
  9. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Continue reassembly: 9 단계, 이미지 1/1
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the display cable bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 10 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 10 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: 10 단계, 이미지 3/3
    • Grab the pull tab on the upper left of the frame and remove the liner covering the perimeter adhesive.
    • Make sure the adhesive doesn't peel up with the liner.
  11. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: 11 단계, 이미지 1/2 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: 11 단계, 이미지 2/2
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
  12. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 12 단계, 이미지 1/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 12 단계, 이미지 2/3 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: 12 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Screen Vise Clamps 6-Pack
    $15.99
    구매
    • To evenly compress your Pixel and strengthen the bond of the screen to the frame, you need to account for the camera bar.
    • If you have screen vise clamps, you can work around the camera bar. Secure the clamps to the perimeter of the device.
    • Apply tape to the perimeter of your rear glass to protect its finish.
    • Place coins or similarly thick objects along the edges of the rear glass. Make sure they're as thick or thicker than the camera bar.
    • Stack multiple books or other heavy objects on your phone. Leave them in place for thirty minutes or longer. Ideally, leave them stacked overnight.
결승점
다른 31명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
257,458 평판
안내서 529개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,893개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 22
7일 전: 128
30일 전: 564
전체 시간: 12,345
