주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Start Up a Mac in Internet Recovery Mode
    1. How to Start Up a Mac in Internet Recovery Mode, How to Start Up a Mac in Internet Recovery Mode: 1 단계, 이미지 1개 중 1개
      • Shut down the computer.
      • If you're installing MacOS to a new drive with Internet Recovery, you can skip this step.
      댓글 쓰기
    2. How to Start Up a Mac in Internet Recovery Mode: 2 단계, 이미지 1개 중 1개
      • Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
      댓글 쓰기
    3. How to Start Up a Mac in Internet Recovery Mode: 3 단계, 이미지 2개 중 1개 How to Start Up a Mac in Internet Recovery Mode: 3 단계, 이미지 2개 중 2개
      • When the spinning globe animation appears, you can release the keys.
      • The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
      댓글 쓰기
    4. How to Start Up a Mac in Internet Recovery Mode: 4 단계, 이미지 1개 중 1개
      • Once a network connection has been established, a progress bar will appear underneath the spinning globe.
      • This process is prone to timing out. If you receive an error, try again using a cable connection to reach the internet rather than WiFi. Depending on your model, you may need an adapter to accomplish this.
      댓글 쓰기
    5. How to Start Up a Mac in Internet Recovery Mode: 5 단계, 이미지 1개 중 1개
      • When Internet Recovery has loaded, you will see the macOS recovery screen.
      댓글 쓰기
결론
From the recovery menus, you can restore your data from a Time Machine backup, Reinstall macOS, get help online, and use Disk Utility to format and diagnose problems with any connected storage drives.
취소: 해당 안내서를 완성하지 않았습니다.
다른 85명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Dixon
회원 가입일: 06/26/18
72,704 평판
안내서 94개를 작성함
44가이드 댓글
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - 답글 공유
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon - 답글 공유
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - 답글 공유
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - 답글 공유
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
Orlando Gomez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 45
지난 7일: 284
지난 30일: 1,256
전체 시간: 566,665
