주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to String a Tennis Racket
필요한 것
  1. How to String a Tennis Racket, Cut the old strings from the tennis racket: 1 단계, 이미지 2개 중 1개 How to String a Tennis Racket, Cut the old strings from the tennis racket: 1 단계, 이미지 2개 중 2개
    • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
    • Be careful not to cut yourself with the ends of the strings.
    댓글 쓰기
  2. How to String a Tennis Racket, Place the frame into a stringing machine: 2 단계, 이미지 1개 중 1개
    • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
    댓글 쓰기
  3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 3 단계, 이미지 3개 중 1개 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 3 단계, 이미지 3개 중 2개 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 3 단계, 이미지 3개 중 3개
    • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
    • Pull and tighten the first main string into a tension rod.
    • The strings should always go under the racquet.
    댓글 쓰기
  4. How to String a Tennis Racket, Secure and tighten the end of the string: 4 단계, 이미지 2개 중 1개 How to String a Tennis Racket, Secure and tighten the end of the string: 4 단계, 이미지 2개 중 2개
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
    • Fix the second string utilizing the second clamp and release the first string.
    • Continue threading the main strings and clamping the strings until all holes have been strung.
    • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
    댓글 쓰기
  5. How to String a Tennis Racket, Knot the main string: 5 단계, 이미지 2개 중 1개 How to String a Tennis Racket, Knot the main string: 5 단계, 이미지 2개 중 2개
    • Knot the main string after you have secured all the main strings.
    • Release the tension rod and cut off the remaining string.
    댓글 쓰기
  6. How to String a Tennis Racket, Horizontal cross strings: 6 단계, 이미지 1개 중 1개
    • Insert the horizontal cross strings from the left to the right and back to the left.
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
    • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
    • Weave the cross strings by going over and under repeatedly through the main strings.
    댓글 쓰기
  7. How to String a Tennis Racket, Knot all the cross strings: 7 단계, 이미지 1개 중 1개
    • Knot all of the cross strings after you have secured them.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Tzu-Wei
회원 가입일: 09/19/20
153 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 53
전체 시간: 5,580
