주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Troubleshoot a GE Top Load Washing Machine Not Starting
비디오 가이드
이 가이드는 YouTube 동영상에서 필사한 것입니다.
필요한 것
      • Ensure the dial is not stripped or cracked by rotating it and listening for a click.
      • Confirm that pressing the start button produces a click sound from the control board.
      댓글 쓰기
      • Examine the lid for any bulging or warping near the striker area.
      • Make sure the striker aligns correctly with the lid lock when the lid closes.
      • Check if the striker is seated flat against the lid and not bent or broken.
      댓글 쓰기
      • Look for clogged mesh filters in the water inlet valves at the back of the machine.
      • Verify that both hot and cold water supply hoses are providing adequate flow.
      • Remove any debris blocking the valves to ensure proper water supply.
      댓글 쓰기
      • Tilt the washer back carefully and look underneath or on the sides for a plastic pouch.
      • Retrieve the technician’s mini-manual for diagnostic codes and wiring schematics.
      • Use an online reference if you cannot find the original tech sheet.
      댓글 쓰기
      • Press and hold the start button for ten seconds, then release it to view error codes.
      • Observe which lights blink alongside pause and lid lock indicators to identify errors.
      • Press the start button repeatedly to cycle through stored codes.
      • Compare the light patterns to the tech sheet or an online resource for exact meaning.
      • Rotate the dial to exit error code mode after viewing the codes.
      댓글 쓰기
      • Press and hold the start button while turning the selector dial seven increments, then release it.
      • Listen for a click and flashing lights to confirm entry into the field service mode.
      • Turn the dial counterclockwise four clicks until only the sensing fill light is on.
      • Press and hold the start button for three seconds to delete stored error codes.
      • Re-run the machine to capture active codes only, aiding in accurate troubleshooting.
      댓글 쓰기
      • Rotate the dial past the error code deletion step to select agitate, spin, or lid lock tests.
      • Use these forced operations to confirm which component fails to function properly.
      • If a mode does not activate, the related part is likely defective.
      댓글 쓰기
      • Unplug the washing machine to avoid electrical hazards.
      • Move the unit away from the wall to access the rear panel.
      댓글 쓰기
      • Remove two 1/4 inch screws from each side of the top panel rear cover.
      • Slide the back metal housing to the right and pull it away to expose the control board.
      • Detach any cardboard or plastic flaps to access the board and the pressure hose.
      • Unplug the pressure hose from the board if you need to fully remove the console.
      • Remove two long screws on each rear corner to free the lid assembly from the chassis.
      • Snap the console forward and press down on two hidden front clips with a putty knife.
      • Lift the top upward to reveal the lid lock and its wiring harness.
      댓글 쓰기
      • Unplug the wiring harness from the lid lock if it is still connected.
      • Release the white plastic bezel by pressing the outside tabs and pushing it out.
      • Use a small screwdriver to press the lock’s top tab and slide the assembly left for removal.
      댓글 쓰기
      • Replace the striker if damaged by removing its two mounting screws on the lid.
      • Align any replacement striker so it fits into the same orientation as the old one.
      • Select a matching GE lid lock assembly if needed and ensure it aligns with the bezel.
      댓글 쓰기
      • Slide the new lid lock into the opening and secure it with a left-to-right motion.
      • Press the bezel back into place, aligning the guiding peg correctly.
      • Reconnect the lid lock wiring harness and make sure it is fully seated.
      • Close the top panel and press down on the front edge to engage the hidden clips.
      • Reinstall the capacitor, screws, and the back metal plate at the control area.
      • Verify the capacitor wires match their original orientation before closing.
      댓글 쓰기
      • Tilt or lay the washing machine on its back, ensuring the drain hose stays above the tub.
      • Support the machine so the lid does not slam open or shut unexpectedly.
      • Use a ratchet to remove the three bottom-cover screws and note the grounding strap.
      • Check the plastic cover for oil stains, belt debris, or broken tabs.
      댓글 쓰기
      • Rotate the pulleys by hand and pull the belt away to slip it off both pulleys.
      • Examine the belt for fraying, grease, or any other visible damage.
      • Clean or replace the belt if it shows signs of slipping or excessive wear.
      댓글 쓰기
      • Use a 15 mm socket and ratchet to loosen the pulley nut counterclockwise.
      • Pry the pulley off gently with a large screwdriver or a specialized puller tool.
      • Inspect the speed sensor for any belt debris or damage and unplug it if needed.
      • Remove the sensor by pressing the side tabs and sliding it off the motor housing.
      • Reconnect the sensor by aligning tabs, plugging the harness, and securing the red lock tab.
      댓글 쓰기
      • Loosen the pulley nut with a socket wrench and tap or pull the pulley off the shaft.
      • Unplug the shifter harness and remove two 3 8 inch screws holding it in place.
      • Support the assembly so the loaded spring does not pop out when the final screw is removed.
      • Check the clutch spring, plastic housing, and shifter assembly for damage or wear.
      • Verify the coil resistance with a multimeter according to the machine’s schematic.
      • Replace any defective parts and reassemble the shifter, spring, and clutch in reverse order.
      댓글 쓰기
      • Align the belt on the motor pulley and begin slipping it onto the transmission pulley.
      • Rotate the transmission pulley to help the belt slide fully into place.
      • Reattach the plastic bottom cover using three screws, including the grounding strap.
      • Set the washer upright and reconnect the power supply to confirm operation.
      댓글 쓰기
결론
After the faulty control, lid-lock, belt, or shifter issue is corrected, run a test cycle and confirm the washer starts and advances normally. Repair didn't go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ben Schlichter
회원 가입일: 01/21/25
7,128 평판
안내서 224개를 작성함
1가이드 댓글
Thank you for sharing your knowledge on GE repair. You just saved this broke housewife a ton of money I didn't have to begin with. But as OCD calls for clean laundry , I knew there had to be an easier way.... Bless you washer repair man...bless you
BAlexa Berkley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 97
지난 30일: 445
전체 시간: 4,085
