주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to True a wheel
필요한 것
  1. How to True a wheel, How to True a wheel: 1 단계, 이미지 2개 중 1개 How to True a wheel, How to True a wheel: 1 단계, 이미지 2개 중 2개
    • Fit the wheel into the wheel truing stand.
    • The wheel should be snug and securely fixed to the stand.
    • Make sure hub does not have play in it since this will impede your ability to true the wheel.
    댓글 쓰기
  2. How to True a wheel: 2 단계, 이미지 2개 중 1개 How to True a wheel: 2 단계, 이미지 2개 중 2개
    • Slowly rotate the wheel.
    • Slowly tighten the calipers until they touch at some point on only one side of the rim.
    댓글 쓰기
  3. How to True a wheel: 3 단계, 이미지 2개 중 1개 How to True a wheel: 3 단계, 이미지 2개 중 2개
    • Select the a spoke wrench that fits the spokes on your wheel.
    • Loosen the spokes that attach to the same side of the wheel as the caliper contact point. At the same time, tighten the spokes that attach to the opposite side of the wheel as the caliper contact point. To start, try a half turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until when tightening the calipers, they touch both sides of the rim evenly at every point on the rim.
    댓글 쓰기
결론
The wheel should spin without wobbling from side to side or wavering up and down.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
aaron thielk
회원 가입일: 10/10/10
1,984 평판
안내서 5개를 작성함
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 회원
CPSU-MANESS-F10S5G13
4 회원들
안내서 21개를 작성함
2가이드 댓글
This is a great instruction manual. I especially appreciated the pictures. For those of us who have never fixed a bike, I would not know what a caliper was without the picture.
Thanks!
edwardslaura234 - 답글 공유
If you don't want to spend money on wheel callipers. Use clothes hanger and tape to the break as a guide.
deankjm - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 28
전체 시간: 7,999
