주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Use Suction Tape
  1. How to Use Suction Tape, Choose the tape: 1 단계, 이미지 2개 중 1개 How to Use Suction Tape, Choose the tape: 1 단계, 이미지 2개 중 2개
    • If you want to secure one side of your two-panel device, skip to this step.
    • If you want to buffer a difficult surface on your device, move to the next step.
    댓글 쓰기
  2. How to Use Suction Tape, Measure the tape: 2 단계, 이미지 3개 중 1개 How to Use Suction Tape, Measure the tape: 2 단계, 이미지 3개 중 2개 How to Use Suction Tape, Measure the tape: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • Measure the length of tape you want and mark it with a pen. Consider the following:
    • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
    • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
    댓글 쓰기
  3. How to Use Suction Tape, Cut the tape: 3 단계, 이미지 3개 중 1개 How to Use Suction Tape, Cut the tape: 3 단계, 이미지 3개 중 2개 How to Use Suction Tape, Cut the tape: 3 단계, 이미지 3개 중 3개
    • Use scissors to cut the tape to the desired length.
    • Repeat the measuring and cutting procedure for each piece of tape required.
    댓글 쓰기
  4. How to Use Suction Tape, Peel the tape: 4 단계, 이미지 2개 중 1개 How to Use Suction Tape, Peel the tape: 4 단계, 이미지 2개 중 2개
    • Peel the tape off its plastic liner.
    댓글 쓰기
  5. How to Use Suction Tape, Apply the tape: 5 단계, 이미지 3개 중 1개 How to Use Suction Tape, Apply the tape: 5 단계, 이미지 3개 중 2개 How to Use Suction Tape, Apply the tape: 5 단계, 이미지 3개 중 3개
    • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
    댓글 쓰기
  6. How to Use Suction Tape, Secure the tape: 6 단계, 이미지 3개 중 1개 How to Use Suction Tape, Secure the tape: 6 단계, 이미지 3개 중 2개 How to Use Suction Tape, Secure the tape: 6 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
    • Use a spudger to press out any large bubbles.
    댓글 쓰기
  7. How to Use Suction Tape, Open the device: 7 단계, 이미지 2개 중 1개 How to Use Suction Tape, Open the device: 7 단계, 이미지 2개 중 2개
    • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
    • You're now ready to open your device!
    • Follow this guide for general instructions on how to use the Anti-Clamp.
    댓글 쓰기
  8. How to Use Suction Tape, Measure the tape: 8 단계, 이미지 3개 중 1개 How to Use Suction Tape, Measure the tape: 8 단계, 이미지 3개 중 2개 How to Use Suction Tape, Measure the tape: 8 단계, 이미지 3개 중 3개
    • The remaining steps show how to secure one side of your two-panel device.
    • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
    • In this example, we want to open the screen, so we'll secure the blue back cover.
    • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
    • Use enough tape to ensure a good hold on the panel you don't want to open.
    • Don't cover the power button with tape, or you might accidentally turn on the device.
    댓글 쓰기
  9. How to Use Suction Tape, Peel the tape: 9 단계, 이미지 2개 중 1개 How to Use Suction Tape, Peel the tape: 9 단계, 이미지 2개 중 2개
    댓글 쓰기
  10. How to Use Suction Tape, Cut the tape: 10 단계, 이미지 2개 중 1개 How to Use Suction Tape, Cut the tape: 10 단계, 이미지 2개 중 2개
    댓글 쓰기
  11. How to Use Suction Tape, Apply the tape: 11 단계, 이미지 3개 중 1개 How to Use Suction Tape, Apply the tape: 11 단계, 이미지 3개 중 2개 How to Use Suction Tape, Apply the tape: 11 단계, 이미지 3개 중 3개
    • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
    • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
    댓글 쓰기
  12. How to Use Suction Tape, Fold the tape: 12 단계, 이미지 3개 중 1개 How to Use Suction Tape, Fold the tape: 12 단계, 이미지 3개 중 2개 How to Use Suction Tape, Fold the tape: 12 단계, 이미지 3개 중 3개
    • Fold the tape onto the panel you don't want to open.
    • Use your fingers to press down the tape and firmly secure it to your device.
    댓글 쓰기
  13. How to Use Suction Tape, Open the device: 13 단계, 이미지 2개 중 1개 How to Use Suction Tape, Open the device: 13 단계, 이미지 2개 중 2개
    댓글 쓰기
결론
For other general electronics skills guides, click here.
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
245,335 평판
안내서 1,203개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,535개를 작성함
3가이드 댓글
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - 답글 공유
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - 답글 공유
I would like to check the material of this product. Anyone can help me?
Nguyễn Thị Vân Anh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 73
지난 30일: 317
전체 시간: 11,989
