주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Iron a Waterproof Jacket
필요한 것
  1. How to Iron a Waterproof Jacket, Prepare the jacket: 1 단계, 이미지 1개 중 1개
    • Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
    • You only want to iron through one layer of the jacket at a time. Ironing through two layers can create creases in the bottom layer.
    • Flatten your jacket with your hands.
    댓글 쓰기
  2. How to Iron a Waterproof Jacket, Set up the iron: 2 단계, 이미지 3개 중 1개 How to Iron a Waterproof Jacket, Set up the iron: 2 단계, 이미지 3개 중 2개 How to Iron a Waterproof Jacket, Set up the iron: 2 단계, 이미지 3개 중 3개
    • Set the iron to its lowest heat setting, below 230 °F.
    • Turn off the steam function. Steam can damage the fabric and the DWR coating. If you can't turn off the steam function on your iron, drain the water chamber completely.
    댓글 쓰기
  3. How to Iron a Waterproof Jacket, Protect the jacket: 3 단계, 이미지 2개 중 1개 How to Iron a Waterproof Jacket, Protect the jacket: 3 단계, 이미지 2개 중 2개
    댓글 쓰기
  4. How to Iron a Waterproof Jacket, Iron the jacket: 4 단계, 이미지 2개 중 1개 How to Iron a Waterproof Jacket, Iron the jacket: 4 단계, 이미지 2개 중 2개
    • Iron in one smooth stroke, running parallel to the zipper.
    • Only iron in one direction, don't go back and forth or you risk creating creases. Change directions only when you move to a new section of the jacket.
    • Don't press down. Let the heat and weight of the iron do the work.
    • Keep the iron moving continuously to avoid melting or burning the fabric.
    댓글 쓰기
  5. How to Iron a Waterproof Jacket, Check your progress: 5 단계, 이미지 3개 중 1개 How to Iron a Waterproof Jacket, Check your progress: 5 단계, 이미지 3개 중 2개 How to Iron a Waterproof Jacket, Check your progress: 5 단계, 이미지 3개 중 3개
    • Remove the towel and inspect the jacket.
    • If the fabric looks unchanged, increase the heat slightly and try again.
    • If the area looks smooth, move on to the next section.
    댓글 쓰기
    • To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
    • Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
    • For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
    • Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
    • Don't forget to turn off the iron when you're finished.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,568 평판
안내서 19개를 작성함
Patagonia Patagonia 회원
Community
9 회원들
안내서 155개를 작성함
17가이드 댓글
Thank you, good advice for younger generation who have clue.
keirakeith26 - 답글 공유
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - 답글 공유
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - 답글 공유
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - 답글 공유
I hope the non-English comment is also in the same form as the first 3.
Eva - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 126
지난 30일: 596
전체 시간: 203,733
