주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to adjust Razor A steering column
    1. How to adjust Razor A steering column, How to adjust Razor A steering column: 1 단계, 이미지 2개 중 1개 How to adjust Razor A steering column, How to adjust Razor A steering column: 1 단계, 이미지 2개 중 2개
      • Locate the tightening assembly. The tightening assembly consists of:
      • An upper nut
      • A lower nut
      댓글 쓰기
    2. How to adjust Razor A steering column: 2 단계, 이미지 1개 중 1개
      • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
      • If loosening the steering column, follow these steps:
      • Turn the upper nut counterclockwise.
      • Turn the lower nut counterclockwise until it is tight against the upper nut.
      • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
      • If tightening the steering column, follow these steps:
      • Turn the lower nut clockwise until reaching the desired steering column tightness.
      • Turn the upper nut clockwise until it is tight against the lower nut.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jordyn
회원 가입일: 10/09/12
565 평판
안내서 5개를 작성함
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G13
4 회원들
안내서 10개를 작성함
8가이드 댓글
what move it with your hands? - didn't help
Heather McCasland - 답글 공유
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 - 답글 공유
Thanks you! Why doesn't the owners manual have this?
Jessica - 답글 공유
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - 답글 공유
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 120
전체 시간: 44,163
