주요 콘텐츠로 건너뛰기
How to bleed the RockShox Reverb Stealth
필요한 것
  1. How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 1 단계, 이미지 1/3 How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 1 단계, 이미지 2/3 How to bleed the RockShox Reverb Stealth, How to bleed the RockShox Reverb Stealth: 1 단계, 이미지 3/3
    • Use an allen key to loosen the screws which hold the saddle in its place.
    • Remove the saddle and the upper part of its clamp.
    • Use an allen key to loosen the seat post clamp.
  2. How to bleed the RockShox Reverb Stealth: 2 단계, 이미지 1/3 How to bleed the RockShox Reverb Stealth: 2 단계, 이미지 2/3 How to bleed the RockShox Reverb Stealth: 2 단계, 이미지 3/3
    • Remove the screw which is holding the gearshift in its place with an allen key.
    • Put the gearshifts to the side.
    • Loosen the clamp screw from the Reverb-remote until you can move it.
  3. How to bleed the RockShox Reverb Stealth: 3 단계, 이미지 1/3 How to bleed the RockShox Reverb Stealth: 3 단계, 이미지 2/3 How to bleed the RockShox Reverb Stealth: 3 단계, 이미지 3/3
    • Install and orient the remote on the handlebar with the bleed port level, or at the highest point.
    • Remove the seatpost.
    • Attach the seatpost to the rear wheel with zip ties. Avoid any tension on the hose.
  4. How to bleed the RockShox Reverb Stealth: 4 단계, 이미지 1/2 How to bleed the RockShox Reverb Stealth: 4 단계, 이미지 2/2
    • Rotating the speed adjuster to the slowest setting is critical for a successful bleed. Failure to do so may result in insufficient fluid volume inside the hydraulic remote system.
    • Draw 20 ml of Reverb hydraulic fluid into the syringe. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe.
  5. How to bleed the RockShox Reverb Stealth: 5 단계, 이미지 1/2 How to bleed the RockShox Reverb Stealth: 5 단계, 이미지 2/2
    • Remove the bleed screw.
    • Thread the standard syringe bleed fitting into the remote bleed port.
  6. How to bleed the RockShox Reverb Stealth: 6 단계, 이미지 1/3 How to bleed the RockShox Reverb Stealth: 6 단계, 이미지 2/3 How to bleed the RockShox Reverb Stealth: 6 단계, 이미지 3/3
    • Draw 5 ml of fluid into the second RockShox bleed syringe. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe.
    • Remove the bleed screw at the seat post and thread the standard syringe bleed fitting into the seat post bleed port.
    • Depress the remote syringe plunger while pulling the seatpost syringe plunger out.
    • Do not empty the syringe. Leave at least 5 ml of fluid in each syringe during the procedure to avoid air entering the system.
    • Depress the seatpost syringe plunger while pulling the remote syringe plunger out. Repeat these steps until bubbles are no longer pulled from the remote and seatpost.
  7. How to bleed the RockShox Reverb Stealth: 7 단계, 이미지 1/2 How to bleed the RockShox Reverb Stealth: 7 단계, 이미지 2/2
    • Remove the syringe from the seat post. Install the bleed screw and tighten it. Spray isopropyl alcohol on the seatpost and hydraulic hose and clean them with a shop towel.
    • Pull up on the syringe plunger and push the remote actuator. Depress the syringe plunger until the actuator fully extends. Repeat this process until bubbles are no longer pulled from the remote into the syringe. Then remove the syringe. Install the bleed screw and tighten it. Spray isopropyl alcohol on the remote and clean it with a shop towel.
결론
To reassemble your bike, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,989 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 92
전체 시간: 6,872
