주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
How to fix mouse wheel clicks on G903
  1. How to fix mouse wheel clicks on G903, How to fix mouse wheel clicks on G903: 1 단계, 이미지 1개 중 1개
    • Remove the screw.
    • Pull it apart into two pieces.
    • If you remove the default sole, you can't put it back on, so you need to buy it in advance.
    • Six screws in total.
  2. How to fix mouse wheel clicks on G903: 2 단계, 이미지 1개 중 1개
    • Remove the pin by pushing it with a thin stick or screwdriver
    • Lift the wheel off
  3. How to fix mouse wheel clicks on G903: 3 단계, 이미지 1개 중 1개
    • Peel off the Kapton tape on the metal dome switch and take out the metal plate inside
    • Remove all of the kapton tape
    • Once it's gone, it's almost impossible to find it, so don't lose it.
  4. How to fix mouse wheel clicks on G903: 4 단계, 이미지 1개 중 1개
    • Bend so that the center rises by about 0.2mm
    • What to do after fixing firmly
    • Do not over bend
  5. How to fix mouse wheel clicks on G903: 5 단계, 이미지 1개 중 1개
    • Put the metal plate back
    • Affix Kapton tape to fix (if not available, sellotape can be substituted.)
    • Shape Kapton tape (scotch tape) with a cutter, etc.
결론
To reassemble your device, follow these steps in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
jp en
85%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
Furumatsu Keita
회원 가입일: 11/07/22
228 평판
안내서 1개를 작성함
1가이드 댓글
Putting a tiny kink into the metal dome worked perfectly. And I already had a roll of Kapton tape on hand. I never would've realized the little dome was only held on by the tape if not for this guide. Just figured the tape was there to prevent shorting on top or something. That thought made little sense once I saw a bunch of these buttons available and designed without tape but a metal case instead.
Themicles - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 203
전체 시간: 4,600
