주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to fix squeaky trucks
필요한 것
    1. How to fix squeaky trucks, How to fix squeaky trucks: 1 단계, 이미지 1개 중 1개
      • Begin by determining which of your trucks are making squeaky sounds when you turn
      댓글 쓰기
    2. How to fix squeaky trucks: 2 단계, 이미지 1개 중 1개
      • Begin by taking off the kingpin nut with your crescent wrench. Alternatively, Standard kingpin nut size is 3/8" so a wrench of equal size should work. The kingpin nut has been screwed off in the picture.
      댓글 쓰기
    3. How to fix squeaky trucks: 3 단계, 이미지 1개 중 1개
      • Take off the washer between the kingpin nut and the white rubber bushing. Note the direction the washer was facing (Concave side towards the board or away) as it will need to be installed back the same way.
      댓글 쓰기
    4. How to fix squeaky trucks: 4 단계, 이미지 1개 중 1개
      • Pull off the white rubber bushing and set it down next to the washer.
      댓글 쓰기
    5. How to fix squeaky trucks: 5 단계, 이미지 2개 중 1개 How to fix squeaky trucks: 5 단계, 이미지 2개 중 2개
      • Pull the hanger (horizontal metal bar attached to the wheels) out of the pivot cup and off of the kingpin bolt and set it aside.
      댓글 쓰기
    6. How to fix squeaky trucks: 6 단계, 이미지 2개 중 1개 How to fix squeaky trucks: 6 단계, 이미지 2개 중 2개
      • Scrape off a small amount of bar soap and place it in the pivot cup (the green hole in picture 2) NOTE: Do NOT use liquid soap for this procedure
      댓글 쓰기
    7. How to fix squeaky trucks: 7 단계, 이미지 1개 중 1개
      • Insert the hanger back onto the kingpin and into the pivot cup and work it around a little bit to spread the soap
      댓글 쓰기
    8. How to fix squeaky trucks: 8 단계, 이미지 1개 중 1개
      • Put the white rubber bushing back on the kingpin bolt, followed by the washer.
      댓글 쓰기
    9. How to fix squeaky trucks: 9 단계, 이미지 2개 중 1개 How to fix squeaky trucks: 9 단계, 이미지 2개 중 2개
      • After you have added on the washer, screw on the kingpin nut and tighten to preference. The tighter the nut the stiffer the turning capability, so this is personal preference. Usually I find that screwing it on until 1 or 2 threads of the kingpin bolt are visible above the nut is sufficient.
      댓글 쓰기
      • If you find that you have put too much soap in the bearings and the board is no longer stable when standing on it, you can clean out the pivot cup by following the above instructions to remove the hardware to get to the pivot cup and cleaning it out with a paper towel or other material.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
John
회원 가입일: 07/16/13
222 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 46
전체 시간: 41,777
