소개
Before reading this guide, ensure you know how to strip wires and solder a connection. If not, please look at the following guides.
Stripping Wire: Wire Stripping
Soldering:How To Solder and Desolder Connections
필요한 것
Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
