소개
Use this guide to open your Huawei Watch GT 3 (46 mm) for repairs.
필요한 것
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Remove the four 3.7 mm-long Torx T2 screws securing the back cover.
Insert the edge of a spudger into the the loudspeaker opening at the bottom edge of your watch.
Use a spudger to pry up the rear panel of your Huawei watch GT 3.
Carefully swing the rear panel assembly open to an upward position.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
다른 한 분이 해당 안내서를 완성하였습니다.
