주요 콘텐츠로 건너뛰기
How to open the Huawei Watch GT
필요한 것
  1. How to open the Huawei Watch GT, How to open the Huawei Watch GT: 1 단계, 이미지 1/1
    • Before you begin, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to open the Huawei Watch GT: 2 단계, 이미지 1/1
    • Remove the four Torx T3 screws (3.65 mm length).
  3. How to open the Huawei Watch GT: 3 단계, 이미지 1/3 How to open the Huawei Watch GT: 3 단계, 이미지 2/3 How to open the Huawei Watch GT: 3 단계, 이미지 3/3
    • Insert an opening pick into the notch at the top edge of the back cover.
    • Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage to other components.
    • Use the opening pick to pry up the back cover of the Huawei Watch GT.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  4. How to open the Huawei Watch GT: 4 단계, 이미지 1/2 How to open the Huawei Watch GT: 4 단계, 이미지 2/2
    • Carefully fold the back cover assembly to the side of the two watch crowns.
결론
To reassemble your Huawei Watch GT, follow these instructions in reverse order.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
다른 2명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 2개
Do you know what size the internal screws are for the HUAWEI gt2 watch? I managed to drop one into a black hole.
keegs_2090 - 답글
Hi keegs_2090!
The internal screws are 2.9 mm-long #000 Phillips screws with a 1.8 mm-wide head.
Dominik Schnabelrauch -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 29
30일 전: 131
전체 시간: 2,517
