주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to remove malware from an infected windows PC
필요한 것
  1. How to remove malware from an infected windows PC, Install Anti-Malware software: 1 단계, 이미지 2개 중 1개 How to remove malware from an infected windows PC, Install Anti-Malware software: 1 단계, 이미지 2개 중 2개
    • On the PC you will be doing antivirus on, install the appropriate software. If the PC with malware does not turn on, install on a different one to do anti-virus.
    • Malwarebytes is great anti-virus software. Go to the website and install it for free.
    • Glarysoft Malware hunter is also good. Their website is here.
    • Other free anti-malware works too, but these are my favorites.
    댓글 쓰기
  2. How to remove malware from an infected windows PC, Remove your SATA HDD/SDD from the PC: 2 단계, 이미지 1개 중 1개
    • This step only applies to PCs that do not boot. If the PC with malware runs, then install the software directly onto it.
    • Because assembly of different laptops and PCs vary so much, you will have to figure out or find a guide to remove your drive.
    댓글 쓰기
  3. How to remove malware from an infected windows PC, Connect the drive: 3 단계, 이미지 1개 중 1개
    • This step also only applies to PCs that don't boot.
    • If your non-infected PC is a desktop, you may unplug the optical drive and plug the connections into the HDD or SSD. If it is a laptop, you will need a SATA to USB adapter.
    • Shut down your desktop before unplugging the DVD drive and attaching the HDD.
    댓글 쓰기
  4. How to remove malware from an infected windows PC, Disinfect your PC: 4 단계, 이미지 3개 중 1개 How to remove malware from an infected windows PC, Disinfect your PC: 4 단계, 이미지 3개 중 2개 How to remove malware from an infected windows PC, Disinfect your PC: 4 단계, 이미지 3개 중 3개
    • Once you've installed the necessary programs and (if applicable) connected you're infected drive to you PC, you are ready to be the doctor.
    • Run Malwarebytes.
    • Run Glarysoft Malware Hunter.
    • Windows defender comes preinstalled with Windows. Use that also.
    댓글 쓰기
  5. How to remove malware from an infected windows PC, Double checking another PCs drive.: 5 단계, 이미지 1개 중 1개
    • This is the last step for checking another PCs drive
    • Go into file explorer, right click on the drive from the infected PC, and select each of the highlighted options.
    댓글 쓰기
  6. How to remove malware from an infected windows PC, Finito!: 6 단계, 이미지 1개 중 1개
    • All done! follow these instructions in reverse to put everything back.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 40명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
George A.
회원 가입일: 12/07/16
22,563 평판
안내서 4개를 작성함
Community Protectors Community Protectors 회원
Community
21 회원들
안내서 31개를 작성함
1가이드 댓글
changed “boot” to “turn on” because it would make more sense to the people who read this article, as they could be the much less computer-savvy people
aaaaaaaaaaaaaaaaa - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 38
지난 30일: 224
전체 시간: 12,307
