주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to remove pilling
필요한 것
    1. How to remove pilling, Material preparation: 1 단계, 이미지 3개 중 1개 How to remove pilling, Material preparation: 1 단계, 이미지 3개 중 2개 How to remove pilling, Material preparation: 1 단계, 이미지 3개 중 3개
      • Lay out the garment on a clean surface. Prepare the pilling shaver.
      댓글 쓰기
    2. How to remove pilling, Remove the pilling: 2 단계, 이미지 3개 중 1개 How to remove pilling, Remove the pilling: 2 단계, 이미지 3개 중 2개 How to remove pilling, Remove the pilling: 2 단계, 이미지 3개 중 3개
      • Smooth the garment to make sure it is flat before starting.
      • Make little circles with light pressure on the damaged fabric. The pilling will be cut away by the shaver.
      댓글 쓰기
    3. How to remove pilling, Finished and ready!: 3 단계, 이미지 3개 중 1개 How to remove pilling, Finished and ready!: 3 단계, 이미지 3개 중 2개 How to remove pilling, Finished and ready!: 3 단계, 이미지 3개 중 3개
      • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
      • Be sure to clean the lint from inside your shaver after use.
      댓글 쓰기
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,548 평판
안내서 68개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 172개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 32
전체 시간: 745
