주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to start a new guide
  1. How to start a new guide, Get into the guide maker: 1 단계, 이미지 1개 중 1개
    • Click Fix Your Stuff, then click Repair guides. You should see this screen. Then Click Create a Guide.
    댓글 쓰기
  2. How to start a new guide, Setup Part 1: 2 단계, 이미지 1개 중 1개
    • 2: Add your device in Device, on "What part are you replacing", type what you are replacing. and type a title. If you click Show More, you can type an introduction.
    댓글 쓰기
  3. How to start a new guide, Setup Part 2: 3 단계, 이미지 1개 중 1개
    • Fill out the remaining setup, these are not necesarry but these help you be more specific:
    • Time Estimate: You can set the amount of time required to fix this product
    • Difficulty estimate: The difficulty estimate shown is Moderate, which is the default estimate. Can be configured to set a difficulty.
    • Prerequisite guides: Sometimes devices have hidden "prerequisite-only" guides that can be placed into your guide to avoid writing tons of steps. Also, you can use the the back cover/screen replacement guides as a starting Prerequisite. All prerequisites have to be in order.
    • Tools and Parts: You can add tools and/or parts to your guide.
    • Conclusion: Give the reader after-repair instructions.
    댓글 쓰기
결론
Your'e all done setting up your guide! You can start posting steps.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
redratchet21
회원 가입일: 01/29/26
2,854 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 33
전체 시간: 98
