주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to test an Ethernet Cable
필요한 것
    1. How to test an Ethernet Cable, Ports: 1 단계, 이미지 2개 중 1개 How to test an Ethernet Cable, Ports: 1 단계, 이미지 2개 중 2개
      • The tester has two ports on each part:
      • RJ11 (6P2C)
      • RJ45 (8P8C)
      댓글 쓰기
    2. How to test an Ethernet Cable, Connect the cable: 2 단계, 이미지 1개 중 1개
      • Connect one end of the cable on one half of the tester each.
      • If you are testing jacks you can just connect them with a known good patch cable.
      • If the other side of your cable is already connected to a switch or some other device you can connect the MASTER device only.
      • Only do this with cable testers you trust, since crappy cable testers might not limit the current they send through the data lines.
      댓글 쓰기
    3. How to test an Ethernet Cable, Switch on the tester: 3 단계, 이미지 1개 중 1개
      • Switch on the tester.
      • The tester has two modes: ON and S. There is no difference in the two modes besides the testing interval on S being more drawn out.
      댓글 쓰기
    4. How to test an Ethernet Cable, Test the cable: 4 단계, 이미지 1개 중 1개
      • The tester will go through all the wires in sequence. If the sequence of the green lights blinking does not line up you might have swapped some wires when wiring the connector.
      • If some lights do not light up there might be a break in the cable or you made a mistake when crimping the connector.
      • For Fast Ethernet (100 Mbit/s) you only need pins 1, 2, 3 and 6. Some cheap cables may not even have more than these four wires.
      • G means ground. For most consumer applications up to 1GbE it should be fine if your ground is not properly connected.
      댓글 쓰기
결론
Good luck on your next project!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
33,392 평판
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 89
지난 30일: 373
전체 시간: 22,188
