주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei Honor 6x Front Camera Replacement
필요한 것
    1. Huawei Honor 6x Front Camera  Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
      • Turn off the device.
      댓글 쓰기
    2. Huawei Honor 6x Front Camera  Replacement: 2 단계, 이미지 2개 중 1개 Huawei Honor 6x Front Camera  Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the SIM Card Eject Tool into the SIM card tray hole.
      • Press the eject tool into the hole until the tray clicks open.
      댓글 쓰기
    3. Huawei Honor 6x Front Camera  Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the SIM tray from the device using two fingers.
      • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
      댓글 쓰기
    4. Huawei Honor 6x Front Camera  Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the SIM card from the compartment using two fingers.
      댓글 쓰기
    1. Huawei Honor 6x Front Camera  Replacement, Back Cover: 5 단계, 이미지 2개 중 1개 Huawei Honor 6x Front Camera  Replacement, Back Cover: 5 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
      • Pry the screen off the back of the phone by pushing down on the opening tool.
      댓글 쓰기
    2. Huawei Honor 6x Front Camera  Replacement: 6 단계, 이미지 3개 중 1개 Huawei Honor 6x Front Camera  Replacement: 6 단계, 이미지 3개 중 2개 Huawei Honor 6x Front Camera  Replacement: 6 단계, 이미지 3개 중 3개
      • Slide the opening tool or spudger along the bottom of the phone and around the edge.
      댓글 쓰기
    3. Huawei Honor 6x Front Camera  Replacement: 7 단계, 이미지 2개 중 1개 Huawei Honor 6x Front Camera  Replacement: 7 단계, 이미지 2개 중 2개
      • Once three sides of the screen are detached, pry the phone apart using two hands.
      • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
      댓글 쓰기
    4. Huawei Honor 6x Front Camera  Replacement: 8 단계, 이미지 3개 중 1개 Huawei Honor 6x Front Camera  Replacement: 8 단계, 이미지 3개 중 2개 Huawei Honor 6x Front Camera  Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the five 4mm Phillips #00 screws using a screwdriver.
      댓글 쓰기
    5. Huawei Honor 6x Front Camera  Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the motherboard cover from the device using a spudger or your fingers.
      댓글 쓰기
    1. Huawei Honor 6x Front Camera  Replacement, Front Camera: 10 단계, 이미지 3개 중 1개 Huawei Honor 6x Front Camera  Replacement, Front Camera: 10 단계, 이미지 3개 중 2개 Huawei Honor 6x Front Camera  Replacement, Front Camera: 10 단계, 이미지 3개 중 3개
      • Pry the seven connectors off using a spudger or your finger.
      댓글 쓰기
    2. Huawei Honor 6x Front Camera  Replacement: 11 단계, 이미지 3개 중 1개 Huawei Honor 6x Front Camera  Replacement: 11 단계, 이미지 3개 중 2개 Huawei Honor 6x Front Camera  Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the four 2 mm Phillips #00 screws.
      댓글 쓰기
    3. Huawei Honor 6x Front Camera  Replacement: 12 단계, 이미지 2개 중 1개 Huawei Honor 6x Front Camera  Replacement: 12 단계, 이미지 2개 중 2개
      • Lift the motherboard off of the phone using a spudger or two fingers.
      • The left side of the motherboard has a strip of rubber that may need some prodding from a spudger to remove.
      댓글 쓰기
    4. Huawei Honor 6x Front Camera  Replacement: 13 단계, 이미지 2개 중 1개 Huawei Honor 6x Front Camera  Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the cable connecting the camera from the motherboard using a spudger or your finger.
      댓글 쓰기
    5. Huawei Honor 6x Front Camera  Replacement: 14 단계, 이미지 3개 중 1개 Huawei Honor 6x Front Camera  Replacement: 14 단계, 이미지 3개 중 2개 Huawei Honor 6x Front Camera  Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the front camera out from the motherboard by pushing on it with the tip of a spudger.
      • This is best done from the back side of the motherboard and pushing where the cable meets the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tessa Kemper
회원 가입일: 10/08/18
591 평판
안내서 3개를 작성함
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018 회원
CPSU-WHITE-F18S13G5
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 60
전체 시간: 1,549
