주요 콘텐츠로 건너뛰기
Huawei P10 Back Cover Replacement
필요한 것
  1. Huawei P10 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Huawei P10 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Huawei P10 Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Back Cover Replacement: 2 단계, 이미지 1/3 Huawei P10 Back Cover Replacement: 2 단계, 이미지 2/3 Huawei P10 Back Cover Replacement: 2 단계, 이미지 3/3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Back Cover Replacement: 3 단계, 이미지 1/2 Huawei P10 Back Cover Replacement: 3 단계, 이미지 2/2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
204,379 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 56
전체 시간: 7,821
