주요 콘텐츠로 건너뛰기
Huawei P30 Pro Main Flex Cable Connectors Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Huawei P30 Pro Main Flex Cable Connectors Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P30 Pro Main Flex Cable Connectors Replacement: 2 단계, 이미지 3개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 2 단계, 이미지 3개 중 2개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 2 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P30 Pro Main Flex Cable Connectors Replacement: 3 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P30 Pro Main Flex Cable Connectors Replacement: 4 단계, 이미지 3개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 4 단계, 이미지 3개 중 2개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P30 Pro Main Flex Cable Connectors Replacement: 5 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 5 단계, 이미지 2개 중 2개
    • If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P30 Pro Main Flex Cable Connectors Replacement: 6 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P30 Pro Main Flex Cable Connectors Replacement: 7 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 7 단계, 이미지 2개 중 2개
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei P30 Pro Main Flex Cable Connectors Replacement, Motherboard Cover with NFC & Charging Coil: 8 단계, 이미지 1개 중 1개
    • Remove the ten Phillips #00 screws (4.3 mm length).
  9. Huawei P30 Pro Main Flex Cable Connectors Replacement: 9 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 9 단계, 이미지 2개 중 2개
    • Slide an opening pick under the black adhesive at the bottom right of the charging coil.
    • Carefully loosen the adhesive with the opening pick.
  10. Huawei P30 Pro Main Flex Cable Connectors Replacement: 10 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 10 단계, 이미지 2개 중 2개
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
  11. Huawei P30 Pro Main Flex Cable Connectors Replacement: 11 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 11 단계, 이미지 2개 중 2개
    • Slide an opening pick under the left side of the motherboard cover.
    • Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
  12. Huawei P30 Pro Main Flex Cable Connectors Replacement: 12 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 12 단계, 이미지 2개 중 2개
    • Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
    • Remove the motherboard cover including the NFC and charging coil.
  13. Huawei P30 Pro Main Flex Cable Connectors Replacement, Battery Disconnect: 13 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement, Battery Disconnect: 13 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  14. Huawei P30 Pro Main Flex Cable Connectors Replacement, Daughterboard Cover: 14 단계, 이미지 1개 중 1개
    • Remove the five Phillips #00 screws (4.3 mm length).
    • Some of these screws may be hidden under adhesive. Carefully peel the adhesive to uncover these screws.
  15. Huawei P30 Pro Main Flex Cable Connectors Replacement: 15 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 15 단계, 이미지 2개 중 2개
    • Slide an opening pick under the top edge of the daughterboard cover.
    • Pry up and unhinge the daughterboard cover by slightly rotating the opening pick.
  16. Huawei P30 Pro Main Flex Cable Connectors Replacement: 16 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the daughterboard cover.
  17. Huawei P30 Pro Main Flex Cable Connectors Replacement, Main Flex Cable Connectors: 17 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement, Main Flex Cable Connectors: 17 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the left main flex cable connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Huawei P30 Pro Main Flex Cable Connectors Replacement: 18 단계, 이미지 2개 중 1개 Huawei P30 Pro Main Flex Cable Connectors Replacement: 18 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the right main flex cable connector from the motherboard.
결론
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,693 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 234
