주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P7 Screen Assembly Replacement
필요한 것
    1. Huawei P7 Screen Assembly Replacement, Front Display Assembly: 1 단계, 이미지 1개 중 1개
      • Cracked screen, but no idea how to start?
      • Keep calm
      • Follow my guide
      댓글 쓰기
    2. Huawei P7 Screen Assembly Replacement: 2 단계, 이미지 3개 중 1개 Huawei P7 Screen Assembly Replacement: 2 단계, 이미지 3개 중 2개 Huawei P7 Screen Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Heat the glass panel on the back to around 85°C so the adhesive loosens
      • Use a plastic spudger or opening tool to gently pry up the glass
      • Carefully work your way around the edges
      • Be careful at the bottom. There is a flex cable running near the back-glass
      • Never use metal tools for this. Metal will scratch the black paint off the backplate
      댓글 쓰기
    3. Huawei P7 Screen Assembly Replacement: 3 단계, 이미지 3개 중 1개 Huawei P7 Screen Assembly Replacement: 3 단계, 이미지 3개 중 2개 Huawei P7 Screen Assembly Replacement: 3 단계, 이미지 3개 중 3개
      • First, we'll disconnect the battery cable
      • Use a philips screwdriver to remove the shield, revealing the battery connection
      • Next, disconnect the LCD/Digitizer ribbon
      댓글 쓰기
    4. Huawei P7 Screen Assembly Replacement: 4 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the battery
      • Use plastic tools to pry the battery off its adhesive
      • Patience is key here
      • Don't bend, puncture or heat the battery.
      댓글 쓰기
    5. Huawei P7 Screen Assembly Replacement: 5 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 5 단계, 이미지 2개 중 2개
      • Heat the front side to about 85°C
      • Using a plastic tool, seperate the display from the frame, but don't pull it too far away.
      댓글 쓰기
    6. Huawei P7 Screen Assembly Replacement: 6 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Flipping the phone over, we can see the display ribbon
      • Make sure none of this cable is stuck to the frame
      댓글 쓰기
    7. Huawei P7 Screen Assembly Replacement: 7 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Pull the display ribbon through the frame
      • Make sure there is not a single glass-shard left on the frame. Any little splinter will cause significant damage to the new screen you're about to place
      댓글 쓰기
    8. Huawei P7 Screen Assembly Replacement: 8 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 8 단계, 이미지 2개 중 2개
      • Tape up the whole frame with double-sided tape for a perfect fit that won't come loose
      • Make sure you don't cover important holes
      • Put the new screen in, sliding the cable first, making sure the whole cable (aswell as the little part sticking out)
      댓글 쓰기
    9. Huawei P7 Screen Assembly Replacement: 9 단계, 이미지 2개 중 1개 Huawei P7 Screen Assembly Replacement: 9 단계, 이미지 2개 중 2개
      • As good as new
      댓글 쓰기
결론
- Never use metal opening tools
- Remove ALL the glass splinters from the frame before re-attaching the new one
- Have fun
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Maxim
회원 가입일: 04/30/14
2,297 평판
안내서 3개를 작성함
iFixers Belgium iFixers Belgium 회원
Business
1 회원
안내서 36개를 작성함
12가이드 댓글
Hallo Paintskill,
Ich habe eine wesentliche Frage. Was muss ich noch beachten, wenn mein Display und das Touchpannel ganz ist und ich aber nur mein Deckglas austauschen möchte. Wie sind diese aneinander geklebt? Wie schwierig ist das?
Und ja, welche doppelseitigen Klebestreifen hast du benutzt?
lg und Danke,
Friendly
Friendly - 답글 공유
Hallo,
Nun ich habs auch selber versucht und wollte sagen.
Mein Deckglas war nur gesprungen, nicht das Display. Also wollte ich daran sparen und nur das Deckglas kaufen. Keine gute Idee... Das ist brutal mit einander verklebt und selbst wenn man es abbekäme müssten wir das empfindliche Display noch vom Kleber reinigen. Das hab ich mit nicht geschafft - und ich war im Labor der Hochschule. Kauft gleich das Display ^^
lg
Friendly
PS: die 85°C zum Kleber aufheizen sind ganz vernünftig.
Friendly - 답글 공유
found nice video about this process here: https://www.youtube.com/watch?v=BD24da5b...
Karel - 답글 공유
I like that helping video.Thanks pal!
Styleart - 답글 공유
I like that helping video.Thanks!
Styleart - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 51
전체 시간: 43,861
