주요 콘텐츠로 건너뛰기
Huawei P8 Lite Loud Speaker Replacement
필요한 것
  1. Huawei P8 Lite Loud Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei P8 Lite Loud Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Loud Speaker Replacement: 2 단계, 이미지 1/3 Huawei P8 Lite Loud Speaker Replacement: 2 단계, 이미지 2/3 Huawei P8 Lite Loud Speaker Replacement: 2 단계, 이미지 3/3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Loud Speaker Replacement, Loudspeaker: 3 단계, 이미지 1/1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Loud Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Loud Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the loudspeaker carefully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,789
