주요 콘텐츠로 건너뛰기
Huawei P9 Front Facing Camera Replacement
필요한 것
  1. Huawei P9 Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 1/3 Huawei P9 Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 2/3 Huawei P9 Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Front Facing Camera Replacement: 2 단계, 이미지 1/2 Huawei P9 Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: 3 단계, 이미지 1/2 Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: 3 단계, 이미지 2/2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 1/3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 2/3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: 4 단계, 이미지 3/3
    • Peel off the conducting fabric.
    • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 1,640
