주요 콘텐츠로 건너뛰기
Huawei P9 Lite Back Cover Replacement
필요한 것
  1. Huawei P9 Lite Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Huawei P9 Lite Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Back Cover Replacement: 2 단계, 이미지 1/1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Back Cover Replacement: 3 단계, 이미지 1/1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 26
전체 시간: 25,131
