주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P9 Lite Display Replacement
필요한 것
  1. Huawei P9 Lite Display Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Huawei P9 Lite Display Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
    댓글 쓰기
  2. Huawei P9 Lite Display Replacement: 2 단계, 이미지 1개 중 1개
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
    댓글 쓰기
  3. Huawei P9 Lite Display Replacement: 3 단계, 이미지 1개 중 1개
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
    댓글 쓰기
  4. Huawei P9 Lite Display Replacement, Loudspeaker: 4 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement, Loudspeaker: 4 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement, Loudspeaker: 4 단계, 이미지 3개 중 3개
    • On the bottom of the phone remove the following screws:
    • Three 2.9 mm Phillips #00 screws
    • Four 3.8 mm Phillips #00 screws
    • Now you can grab the loudspeaker unit and take it out.
    댓글 쓰기
  5. Huawei P9 Lite Display Replacement, Motherboard Shield: 5 단계, 이미지 1개 중 1개
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
    댓글 쓰기
  6. Huawei P9 Lite Display Replacement: 6 단계, 이미지 2개 중 1개 Huawei P9 Lite Display Replacement: 6 단계, 이미지 2개 중 2개
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
    댓글 쓰기
  7. Huawei P9 Lite Display Replacement, Battery: 7 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement, Battery: 7 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement, Battery: 7 단계, 이미지 3개 중 3개
    • Disconnect the motherboard flex cable on both ends and take it away.
    댓글 쓰기
  8. Huawei P9 Lite Display Replacement: 8 단계, 이미지 2개 중 1개 Huawei P9 Lite Display Replacement: 8 단계, 이미지 2개 중 2개
    • Peel off the NFC antenna from the battery.
    • Be careful not to rip or crease the antenna.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Unplug the battery connector.
    댓글 쓰기
  9. Huawei P9 Lite Display Replacement: 9 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement: 9 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $8.95
    • Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
    • Avoid bending the battery and reheat if necessary.
    • Be careful not to damage the display flex cable that runs underneath the battery in the center.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    댓글 쓰기
  10. Huawei P9 Lite Display Replacement, Display: 10 단계, 이미지 2개 중 1개 Huawei P9 Lite Display Replacement, Display: 10 단계, 이미지 2개 중 2개
    • Take the flat end of a spudger to disconnect the display flex cable.
    • Flip the phone over and use an iOpener to soften the adhesive at the edge of the display.
    댓글 쓰기
  11. Huawei P9 Lite Display Replacement: 11 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement: 11 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement: 11 단계, 이미지 3개 중 3개
    • With a suction handle you can lift the display a little bit to create a gap.
    • Insert just the tip of an opening pick in the gap and steadily slide it along the edge towards the top. You may need to go back and forth a few times.
    • Try to get around the corner and behind the top part of the display. Re-position the suction handle if needed.
    • Leave the opening pick behind the display to avoid the re-sealing of the adhesive.
    댓글 쓰기
  12. Huawei P9 Lite Display Replacement: 12 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement: 12 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement: 12 단계, 이미지 3개 중 3개
    • Heat up the iOpener once again and place it on the display to soften the adhesive at the top.
    • Use a second opening pick to slide along the top edge towards the next corner.
    댓글 쓰기
  13. Huawei P9 Lite Display Replacement: 13 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement: 13 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement: 13 단계, 이미지 3개 중 3개
    • As long as the adhesive is warm try to continue to separate the display along the side towards the bottom. Re-heat the iOpener if necessary.
    • Don't overheat the iOpener. Stick to the iOpener instructions.
    • Also heat up the bottom part of the display for the next few steps.
    댓글 쓰기
  14. Huawei P9 Lite Display Replacement: 14 단계, 이미지 3개 중 1개 Huawei P9 Lite Display Replacement: 14 단계, 이미지 3개 중 2개 Huawei P9 Lite Display Replacement: 14 단계, 이미지 3개 중 3개
    • When you worked your way around the display, take a suction handle and lift the top part of the display away from the frame.
    • Slowly but steadily hinge open the bottom part of the display separating the adhesive.
    • Now you can thread the display flex cable through the gap in the frame.
    • When installing the new display make sure to reapply adhesive where necessary.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
134,306 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,220개를 작성함
3가이드 댓글
About release battery ... fishing braided line works better :) battery taken without any destruction.
Slawomir Z. - 답글 공유
Grazie a questa guida ho potuto sostituire batteria e schermo da me. Grazie!
themafiakiller1967 - 답글 공유
Non si può sostituire solo il vetro? X forza anche lcd?
feliciemanuele - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 51
전체 시간: 29,023
