이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Disconnect the motherboard flex, the battery flex and the antenna cable.
Use a spudger to lift the motherboard carefully.
Remove the motherboard assembly.
Remove the seven loudspeaker screws:
Three silver 2.9 mm Phillips #00
Four black 3.8 mm Phillips #00
Unplug the motherboard flex cable and disconnect the antenna cable.
Put both cables aside.
Now remove the daughter board.
Carefully peel off the contact of the vibration motor and take it out.
Also remove the lower microphone housing.
Insert a spudger or thin prying tool at a shallow angle to avoid bending the battery and pry it up from its adhesive.
다른 39명이 해당 안내서를 완성하였습니다.
댓글 7개
I finished to replace the display yesterday and everything is perfect , thanks ifixit
i replaced the display but the touchscreen doesn’t work
You can try to reopen the phone and check if the flex cable is plugged in correctly or if any cable is ripped. If you can’t find any damage and all cables are plugged in correctly it’s possibly an issue with the replacement part.
Hi, could you show how to replace the power button flex cable for a P9 Lite 2017? I would be greatful.
my powerbutton connection is also missing…
