주요 콘텐츠로 건너뛰기
Huawei P9 Rear Camera Replacement
필요한 것
  1. Huawei P9 Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/3 Huawei P9 Rear Camera Replacement, Back Cover: 1 단계, 이미지 2/3 Huawei P9 Rear Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Rear Camera Replacement: 2 단계, 이미지 1/2 Huawei P9 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Rear Camera Replacement, Fingerprint sensor: 3 단계, 이미지 1/2 Huawei P9 Rear Camera Replacement, Fingerprint sensor: 3 단계, 이미지 2/2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Rear Camera Replacement, Rear Camera: 4 단계, 이미지 1/2 Huawei P9 Rear Camera Replacement, Rear Camera: 4 단계, 이미지 2/2
    • Undo the two Phillips #00 screws.
    • Remove the bracket.
    • Mind the connector underneath.
  5. Huawei P9 Rear Camera Replacement: 5 단계, 이미지 1/2 Huawei P9 Rear Camera Replacement: 5 단계, 이미지 2/2
    • Release the connector.
    • Loosen the camera from the motherboard and take it away.
결론
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
다른 5명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
209,996 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 3,530
